What to do with the .bin file in the SD card root folder after fw update?
3084 3 2015-12-29
tankfarms
Can I delete the file? what about using another SD card?
2015-12-29
sdchew
Singapore
Yes you can delete it. I typically leave the log file for posterity...
2015-12-29
tankfarms
sdchew Posted at 2015-12-29 23:36
Thank you, this helps!
2015-12-29
DJI-Amy
Please delete the firmware after you've successfully upgraded or the camera will detect the firmware every time after powering on. You can check the upgrade txt file to check the upgrade result.
2015-12-30
