New 1.6 Firmware Battery to cold Warning
2774 23 2015-12-31
spope
I was able to update my P3P to Firm 1.6 and everything is back up and running. I have been out a few times and everything was good.
Today I put my P3P in the garage for about 4 hour in the off state. I then took it out to fly and when I tried the auto take off I got
Battery to cold warning.. I checked the Temp in the app and it showed 10C for Battery temp.. SO...... Whats the deal no info that I can find
on this???? What temp does this trip at? It was getting late so I just came in and checked the forum but I do not see anything about this yet.
Am I the first?
2015-12-31
DJI-Ken
Flight distance : 1515312 ft
1.6 has battery protection in the software so you don't have an incident in cold weather. a really cold battery is not good to fly with and the battery needs to be in a warmer temperature to power up the Phantom. Just put them in your jacket pockets for a few minutes an they should work.
2015-12-31
pete
Flight distance : 630486 ft
Had the same problem yesterday. Just warm up the batteries and no problem. Flew 3 batteries about 15 min each. 14 degrees calm winds no problems. Just make sure there warm to start.
2016-1-1
chris
Flight distance : 974 ft
We need a battery warmup box hah.. the p3 wont take off until at 10c and the inspire 12c, so no more start and hover to warm your batteries, keep them in a warm place... other thing i did the other morning is I have a small hot water bottle, put it in a pillow case with 4 batteries and had no probs, but make sure the bottle dont leak....
2016-1-1
[RCG]Balthazar
Flight distance : 475371 ft
Norway
DJI-Ken Posted at 2016-1-1 08:24
1.6 has battery protection in the software so you don't have an incident in cold weather. a really c ...
This is great news!
You might wanna increase it a little bit though, I lost mine when the battery temp started just below that.
I even hovered for half a minute and flew pretty smoothly, slowly increasing throttle. Crashed with 51% battery remaining.
Sounds like you are closing in on a solution!
2016-1-1
sifu128
Did you lose your drone with the new protection in place?
2016-1-1
[RCG]Balthazar
Norway
sifu128 Posted at 2016-1-1 18:26
I dont think so because the battery temp was a little (0.05c) bit below 10c and it still started.
2016-1-1
sifu128
Great news!!!
2016-1-1
anthony.wallace
Flight distance : 198776 ft
DJI-Ken Posted at 2016-1-1 07:24
I have had the same problem to day out side temp was 5degrees I am worried now Will a warm battery get to cold inflight on a cold day  and cause a crash
2016-1-1
nigelw
Flight distance : 518084 ft
anthony.wallace Posted at 2016-1-1 20:57
I have had the same problem to day out side temp was 5degrees I am worried now Will a warm battery ...
If you look at the battery info page (tap on the battery icon) on the app, it displays battery temperature.  You will see as it flies it gets warmer rather than colder.
2016-1-1
Seaduner
Flight distance : 7619229 ft
chris@digata.co Posted at 2016-1-1 21:29
We need a battery warmup box hah.. the p3 wont take off until at 10c and the inspire 12c, so no more ...
Here ya go.
Battery warmer
2016-1-1
DJI-Ken
anthony.wallace Posted at 2016-1-1 13:57
Your battery will warm up,as your flying.
2016-1-1
Seaduner
I know that 1.6 firmware has revised the "Battery Protection" scheme, and it's important to update.  What I'd like to know is two things:
1.  Has the routine of shutting off the battery power under any circumstance while flying been removed?
2.  What prior firmware revisions had the "Shut off Battery" protection scheme enabled?  Was it just 1.4 (since 1.5 didn't have a battery update)?
2016-1-1
DJI-Ken
Seaduner Posted at 2016-1-1 22:45
I know that 1.6 firmaware has revised the "Battery Protection" scheme, and it's important to update. ...
The battery update was in 1.5
2016-1-1
Rebel
Banned
2016-1-1
DJI-Ken
Rebel Posted at 2016-1-1 23:28
So the people who never went past 1.4 ...the batteries should be 1.3.2? Is this correct?
I don't see anything about a battery update in the 1.4 release notes, I will look into it Monday.
2016-1-2
Rebel
Banned
2016-1-2
Seaduner
DJI-Ken Posted at 2016-1-2 14:04
I don't recall any battery update in 1.5.   And what everyone at DJI is saying is 1.6 is a must have update with battery optimization, but no detail on exactly what that optimization included.  Many reports have been logged of 1.5 and before firmware shutting of the power during flight, which sounds absurd, but it's happening.  The 1.6 is supposed to fix that.  However, it also decreased horizontal acceleration and max vertical ascent speed.  My V-ascend went from 5m/s to 3m/s.  I notice in the FAQs for Phantom 3P in the DJI site it still states 5m/s for max vertical ascent speed, but that's not the case anymore.
2016-1-2
koine777
Mine did the same thing. I breathed on it for about 15 seconds, put it in and it flew wonderfully.
2016-1-2
Topviewpics
Flight distance : 623232 ft
DJI-Ken Posted at 2016-1-2 10:47
So if I fly with FW 1.4 I run the risk of battery shutting off? or the contrary? Please advise. I am in NY and temps are 0c right now. Thanks!
2016-1-2
DJI-Ken
Seaduner Posted at 2016-1-2 16:02
I don't recall any battery update in 1.5.   And what everyone at DJI is saying is 1.6 is a must hav ...
The 1.6 takes care of all the battery issues. The ascent is 5m/s and descent is 3m/s
2016-1-2
DJI-Ken
Topviewpics Posted at 2016-1-2 16:34
So if I fly with FW 1.4 I run the risk of battery shutting off? or the contrary? Please advise. I  ...
It's advised to update to 1.6 and if in really cold weather, keep your batteries in your jacket pocket or another way t keep them warm.
2016-1-2
toddf.perkins
It seems like my phantom doesn't climb as quickly with the new 1.6 firmware. Am I just imagining things, or are others experiencing similar issues?
2016-1-3
Vitruvius
Flight distance : 22556 ft
Just had this issue. I have flown many times below 0 but I guess I always started with a warm battery. It is below 15 C here 6 months of the year so I can't just move to California to fly my drone. I do put tape over all the air vents when flying below 0 and that seems to really help the heat from the battery and components keep each other warm.
2017-2-13
