NO video feed after firmware change.
1422 10 2016-1-2
bruno.neokino
Hi Guys,
I just made the firmware upgrade of my new OSMO with the latest firmware available (the OSMO_FW_V01.04.01.80, the one from Dec 27th) and directly the video feed went missing. The OSMO is still working, I have every info on the app (like histogram, sound, ...) I can record  or take pictures but the video feed is down(on my iphone 6, it was working proper before the upgrade) so I can't frame anything, instead I have a blackish/grey screen.
I install the OSMO_FW_V01.02.01.60 after ti see if it would fix the bug but apparently not. Same problem.
Any clues?
Thanks
-I deleted the app and reinstalled it.
-I formated SD card.
-I rebooted the wifi via the trigger+on/off button manipulation.
-With the original firmware it was working.
-I use an Iphone 6.
-Lense cap was removed. ;-)
2016-1-2
denis.korosec
congratulations, have the same problem as I and other people Osmo allowed to your shipment for repair, by the new update it has made you the Wifi module broken
2016-1-2
denis.korosec
thank you to the developers
2016-1-2
bruno.neokino
Thanks Denis, that's what I thought...
2016-1-2
ricardoghion
Flight distance : 1042037 ft
Brazil
bruno.neokino Posted at 2016-1-3 00:55
I think DJing not test the fucking Firmware !!!
2016-1-2
DJI-Amy
Would you able to watch the videos in the playback in the app(left bottom corner of the camera view)? Would you please provide a screenshot of your camera view? Also, please upload the upgrade hidden log file in the micro SD card. It's under MISC\LOG.  Please try the following methods:
1) Please try to reinstall the app.
2) Please try to test other mobile devices and SD cards.
3) Please make sure the gimbal ring has been locked and try to checkthe pin connection of gimbal.  Check thecamera connection pin of the gimbal, detach it and remove the red plasticcircle slice in the pin base.
2016-1-3
bruno.neokino
DJI-Amy Posted at 2016-1-4 02:59
Would you able to watch the videos in the playback in the app(left bottom corner of the camera view) ...
Hi Amy so:
Yes I can.
Here is the à video: I was shooting, the app was displaying infos like histogram, but no image as you can see.
Log file: http://we.tl/OXDyBhyOO8
Already done several times.
I tried but nothing is changing...
Thanks for your answer.
2016-1-3
DJI-Amy
bruno.neokino Posted at 2016-1-4 10:35
Hi Amy so:
Would you able to watch the videos in the playback in the app(left bottom corner of the ...
Please contact your local dealer or DJI technical support for repair, this one should have hardware issue with the WIFI module. http://www.dji.com/support/product/osmo
2016-1-4
bruno.neokino
DJI-Amy Posted at 2016-1-4 09:25
Please contact your local dealer or DJI technical support for repair, this one should have hardwar ...
Ok, That is what I did, they will change it. thank you.
2016-1-4
denis.korosec
There is no firmware tested , so you can see how it destroys Osmo
2016-1-4
sdchew
Japan
DJI should really take a page from large companies such as Apple and put some kind of boot loader into their devices. In that way, if the firmware screws up in some way, you can do some low level boot and push a fresh firmware in. Then again maybe DJI has a low level boot loader but for some reason doesn't want people accessing it.
2016-1-4
