Phantom 3 Series Comparison
16547 26 2016-1-4
DJI-Tim
Phantom 3 4K
Phantom 3  Professional & Advanced
Phantom 3  Standard
Aircraft
  Diagonal Size (Excluding Propellers)
  350 mm
  350 mm
  350 mm
  Weight:   (Including Battery and Propellers)
  1280 g
  1280 g
  1216 g
  LiPo Battery
  4S, 15.2V, 68WH 4480mAh Intelligent Flight  Battery
  Charger
  57W
  Professional: 100W Charger
  Advanced: 57W Charger
  57W
  Flight Time
  About 25 mins
  About   23 mins
  About 25 mins
  Max. Flight Speed
  16m/s
  16m/s
  16m/s
Positioning Module
  Outdoors Positioning Module
  GPS
  GPS/GLONASS
  GPS
  Vision Positioning Module
  Vision Positioning System with ultrasonic  sensors
  No
  Hover Accuracy
  Vertical: +/- 0.1 m (when Vision Positioning  is active) or +/- 0.5 m
  Horizontal: +/- 1.5 m
  Vertical: +/- 0.5 m
Phantom 3   4K
Phantom 3   Standard
Camera
   Sensor
    1/2.3",  Effective pixels  12.4M (Total pixels  12.76M)
    1/2.3",  Effective pixels 12M  (Total pixels 12M)
   Video Resolution
   ﹒UHD:   4096x2160p 24/25, 3840x2160p 24/25/30
   ﹒FHD:   1920x1080p 24/25/30/48/50/60
   ﹒HD:   1280x720p 24/25/30/48/50/60
Professional
   ﹒2.7K:   2704x1520p 24/25/30
   ﹒2.7Kp30(29.997)(2704*1520)
   Max. Image Size
   4000 x 3000
   4000 x 3000
   4000 x 3000
   Lens
   FOV 94° 20 mm (35 mm  format equivalent) f/2.8
   focus at ∞
   focus at ∞
   focus at ∞
   Filter Ring
   Yes, Removable to Allow for ND Filters
   No
Phantom 3   4K
Phantom 3   Standard
Remote Controller & Video Downlink
  Max Transmission Distance
  CE:500m;FCC:1200m  (outdoors and unobstructed)
  CE:3500m;FCC:5000m (outdoors  and unobstructed)
  CE:500m;FCC:1000m  (outdoors and unobstructed)
  Video Transmission System
  Built-in DJI WiFi Video Downlink
  Built-in DJI Lightbridge Video Downlink
   Max.  Video Bitrate
  2M bps
  Professional:10Mbps
  Advanced:2Mbps
  2Mbps
   Max  FPV Preview Quality:
  SD 480P @ 30fps
  HD 720P @ 30fps (depending on conditions and  mobile device)
App
  Mobile App
  DJI GO
  DJI GO
  DJI GO
  Intelligent Flight Modes
  Follow Me
  Point of Interest
  Waypoints
  Course Lock
  Home Lock
  Follow Me
  Point of Interest
  Waypoints
  Course Lock
  Home Lock
  Follow Me
  Point of Interest
  Waypoints
  Course Lock
  Home Lock
2016-1-4
quanthonytrang
Flight distance : 419980 ft
So the 4K is essentially a P3Pro with no Lightbridge and no Glonass and SD 480p FPV?
Can I also ask.. how does it achieve 25min flight times if it weighs the same as the PRO and the ADV?
And is the 4K camera interchangeable with the Pro/Adv?
2016-1-4
Michael M
Flight distance : 1984898 ft
I've flown more than the max speed listed here
2016-1-4
DJI-Tim
Michael M Posted at 2016-1-5 14:32
you could of had tail wind
2016-1-5
aaron.ferguson
Flight distance : 1641752 ft
In practice flight time on the P3A/P is more like 15-17 mins.
2016-1-5
Calvette
Flight distance : 103222 ft
quanthonytrang Posted at 2016-1-4 20:53
Can I also ask ...
So on the Pro you have Glonass and GPS and with the 4K you only have one source to find your locations.
Was there conflicts between the two? Does the wi-fi draw less power on the 4K then lightbridge on the Pro?
2016-1-5
Darkfito
Before you said that the pro and adv fpv was the same...
Demonstrated that they not told the whole truth. Now I have my phantom advanced worst with fpv.
If I had knownI had bought professional
2016-1-5
Michael M
DJI-Tim Posted at 2016-1-5 01:27
whats tail wind? is it dangerous to go that fast? Ive gone up to 17-20 + m/s
2016-1-5
CaveDrone
Flight distance : 11549 ft
Michael M Posted at 2016-1-5 10:41
It's simply going with the WIND.  the tail wind speed adds to your flight speed, be careful coming back, the wind speed subtracts, in other words if your Phantom can only fly at  35mph and the wind is 40 mph, you will be going further away at a rate of 5 mph. BYE BYE.... (Better to land it and retrieve it by hand).
2016-1-5
Nink
When they announced the P3 4K I was worried I had "last years model" but the P3P longer range, 720P FPV, a 10Mbps bit rate and Glonass  justifies the price difference.  I also question the longer flight range on a quad that is the same weight and uses the same battery.
2016-1-5
quanthonytrang
Nink Posted at 2016-1-6 10:47
When they announced the P3 4K I was worried I had "last years model" but the P3P longer range, 720P  ...
I couldn't figure that out either. I understand the Standard having no VPS module and therefore extra flight times.
If it isn't the weight.. then...
Could Lightbridge chew up that much power compared to wifi??
Could the 4K have newer propulsion system?
Or maybe its just a misprint...
2016-1-5
DJI-Tim
quanthonytrang Posted at 2016-1-6 08:09
I couldn't figure that out either. I understand the Standard having no VPS module and therefore ex ...
there is a slight difference in the 4K ECS compare to p3p which adds us couple minutes  in the air.
2016-1-5
quanthonytrang
DJI-Tim Posted at 2016-1-6 13:37
there is a slight difference in the 4K ECS compare to p3p which adds us couple minutes  in the air. ...
Are you able to disclose this?
And what motors are they using to achieve this?
An extra 2 minutes for something that weighs the same as the Adv/Pro is remarkable.
2016-1-5
DJI-Tim
quanthonytrang Posted at 2016-1-6 11:25
An extra 2 minutes  ...
They are still using the same motors
2016-1-5
robinway
Flight distance : 629849 ft
Phantom 3 Standard Video Camera Resolution Specification     ﹒2.7Kp30(29.997)(2704*1520)   ﹒FHD:   1920x1080p 24/25/30    ﹒HD:   1280x720p 24/25/30/48/50/60
Resolutions available on my P3S are ﹒2.7Kp 24/25(2704*1520)   ﹒FHD:   1920x1080p 24/25   ﹒HD:   1280x720p 24/25/48/50
What would be the reason that some resolutions are missing/not available  ... ???
2016-1-5
quanthonytrang
robinway Posted at 2016-1-6 16:17
Phantom 3 Standard Video Camera Resolution Specification     ﹒2.7Kp30(29.997)(2704*1520)   ﹒F ...
Change to NTSC to get the additional frame rates.
2016-1-5
Jaymurray33
agree with Aaron, but there is no way the flight times would be different and... What the heck is a Phantom 3 4k? The Pro is 4K.
2016-1-6
DJI-Tim
Jaymurray33 Posted at 2016-1-7 05:19
agree with Aaron, but there is no way the flight times would be different and... What the heck is a  ...
It's a different model of aircraft,  you can check is on our official website  www.dji.com
2016-1-6
Darkfito
DJI-Tim Posted at 2016-1-7 10:59
2016-1-7
medijaa
Flight distance : 83960 ft
Bosnia and Herzegovina
DJI that they said that the difference between the P3A and P3P only camera 4K and HD
and that's just a scam for the difference in price from $ 250 .
I do not understand why the charger from P3A 57W ?
I do not understand why the charger Video Downlink P3P 10MB ,P3A 2MB ?
This should be the same, or at least less than half with P3A and the charger does not make sense to distinguish.
What many did not know when shopping because the traders where
I bought my P3A told to buy a bass that because in my country still has full HD and more than enough.
Suddenly appeared some differences are very great for me and if I had known about it earlier I would have bought a P3P.
2016-1-9
gil
Flight distance : 1379308 ft
Just an observation - the order of the Phantom in the photo at the top do not match the order of the Phantom in the column.  For example, the Phantom Pro & advanced are on the left in the photo; the information for them is listed in the middle column.
2016-1-9
Fieldstone
DJI-Tim Posted at 2016-1-6 21:59
Why are they using the gold stripes on the 4K? Gold is the P3P's signiture color.Is this going to be the new pro? Is DJI being forced to do away with lightbridge?Is DJI trying to widen the gap between the P3P/P3A  and the Inspire?
2016-1-9
jshot22
P3s is not worth the money
2016-1-10
mrk
India
Hi all, I have few doubts regarding the new phantom 3 4K??  Does it won't have the SDK development option inn??? Like point of interest, path way shots etc... Just clarify me pls
2016-1-11
TOROMBO
Here is a video from North Miami !
hope everyone enjoys!
2016-1-11
DJI-Tim
this is a great video but, i would kindly ask you to delete it from here and 3 other posts.
posting the same thing everywhere looks like pure point earning
I like the footage though, it's good you created the thread only for your video
Thank you!
2016-1-11
devil5052
What's better for the price in your opinion?
2016-2-2
