camera wont connect
2090 7 2014-9-25
john_cockwell
Camera will not connect to dji app keep getting connection failed.
2014-9-25
hoota1231
I have the Phantom Connection Broken when trying to connect to camera also. Did you find a fix? I'm using Android 4.4.2
2014-9-26
hd_ultra
Ok you guy's well try to help here. There may be a few step to be taken here.
Has all your firmware been updated.
2014-9-26
hoota1231
hd_ultra@msn.co Posted at 2014-9-27 12:15
Has all your firmware ...
yes, did you read my posting camera connection problem, I explained everything I did
2014-9-26
hd_ultra
hoota1231@gmail Posted at 2014-9-27 12:30
I will have to go and find it.
2014-9-26
DJI-Daniel
China
Hi Sir, What if set your phone to airplane mode or at least shut off the mobile network?
2014-9-27
hd_ultra
Solution: Some Android devices do not allow for both a Wi-Fi connection and a mobile data connection at the same time. When trying to connect to the Phantom 2 Vision+ Wi-Fi network, most devices will check whether an Internet connection has a certain Wi-Fi setting enabled, e.g. Auto network switch or Test for Internet connection. If no Internet connection is found because the Phantom 2 Vision+ creates a non-routable connection it will drop the Phantom 2 Vision+ Wi- Fi network connection and scan for the next available connection. Example: For the Samsung Note 3, carry out the following procedures to solve this issue. Tap Settings -> Wi-Fi, and then tap the “Menu” button. Select “Advanced” then uncheck the “Auto network switch”. You might see a warning that indicates the Internet connection is unstable this message can be ignored.
2014-9-28
hoota1231
Hi guys,  I posted this same problem a few days ago, I got it working by every time I open up the DJI Vision app I had to Bind the camera to phone/tablet QR code on the bottom of my Phantom 2 Vision and what ever I use for display works great every time,  do this and it should connect with no Phantom connection error's..
thanks everyone for the suggestion's. But now I got to post a battery problem!  Battery led's show full charge but with app only 17% charge and my charger wont charge it as it see's it as fully charged???  Phantom came home cause low battery, at least that work's fine..
2014-9-28
