Operation of P2V+ FPV mode
1432 3 2014-9-25
gregory.buchana
I have a new P2V+ (still haven't flown it).  I want to record video in the FPV mode, but I noticed after selecting FPV that the gimbal still adjusts when moving the aircraft pose.  I expected the camera to remain in a fixed postion relative to the aircraft.  Is FPV working or is my expectation wrong?
2014-9-25
hd_ultra
Non-FPV Mode: the gimbal will stabilize across 3-axial for smooth aerial creativity.
FPV Mode (First Person View Mode): Gimbal will lock to the movements of the Phantom for a FPV experience.
2014-9-25
gregory.buchana
hd_ultra@msn.co Posted at 2014-9-25 22:53
FPV Mode (First ...
Yes, I understand this is the expected behavior.  Any thoughts on why I am still seeing the gimbal move in FPV mode?
2014-9-25
hd_ultra
If you want it to stay straight then turn off FPV mode. By turning it off it should stabilize and move with the phantom.
If when you are in FPV mode the camera should try to stay level.
As the phantom moves and tilts the camera should try to stay level.
Switched on, the gimbal will work in FPV mode. Switched off, the gimbal will work in Stabilize mode.
Hope it helps.
My Youtube Channel
https://www.youtube.com/channel/UC6fqGgjRbBF83v1MF-TqfHA
2014-9-25
