H3-3D Gimbal is DEAD!!
989 6 2015-1-1
thomaskim558
Flight distance : 865177 ft
Yesterday, I just updated my H3-3D Gimbal to V10.0.0.1 and when I turn on, it's not working . I tried the factory reset and downloaded again, but it's still not working. Any solutions?
2015-1-1
gil
Flight distance : 1379308 ft
Did you get one of the new remote controls with the gimbal thumbwheel? (that's the only reason why you would need to do that update)
In the Vision Assistant software, did you select the correct transmitter type (basic or advanced)?
Try this:
2015-1-1
thomaskim558
gil@wk.net Posted at 2015-1-2 15:10
Did you get one of the new remote controls with the gimbal thumbwheel? (that's the only reason why y ...
It's just not moving
2015-1-2
gil
Uhh, you're going to have to be a LOT more specific than "It's just not moving" if you expect anybody to help figure out your problem!    Details dude!
For starters, identify WHICH remote control you have and please verify whether or not you actually went through the Transmitter calibration WITHOUT SOFTWARE.  And what, if anything, happened.  When you power on the Phantom, does the gimbal go through any of it's self test movements?  Are you saying it's not moving then?
2015-1-2
thomaskim558
gil@wk.net Posted at 2015-1-3 06:09
Uhh, you're going to have to be a LOT more specific than "It's just not moving" if you expect anybod ...
Well I don't need to because I  fixed! it!
2015-1-2
Gerry1124
thomaskim558@gm Posted at 2015-1-3 10:36
What did you do to fix it?  Enquiring minds would like to know.
2015-1-2
thomaskim558
Gerry1124 Posted at 2015-1-3 10:38
1. Factory Reset 2. Don't turn off the phantom 2 just connect to the assistant software v3.0 3. If the Gimbal firmware is gone, re-download 4. Turn off and Turn on with go pro on 5. It will work if you followed in order
2015-1-2
