productofusa
Yes I can control the gimbal, Everything works great with the exception of the NO SIGNAL thing, The screen is blank (black) there is no view from the camera. Also the camera works fine, shoots stills and video no problem, it just wont show up on the RC. Full bars on controller and lightbridge (HD). X3, completely stock, brand new. I should mention this is with an Nexus that works great with Phantom 3 Pro.
This is what I emailed to support,
Hello- I recently purchased the Matrice 100, after assembly the only thing that has not worked is camera view on the RC. To be more clear I get the red "NO SIGNAL" and a blank (black) screen on the RC. The camera works fine as i've taken still shots as well as video in 1080 @60 frames/sec it just won't show up on the RC. Also I get full bars on RC TX/RX and full bars on Lightbridge (HD), and 16 or 17 Satellites on the GPS. Things i've tried to fix this,
Pull off upper plate and double check ALL connections including the four lightbridge antenna connections, they were fine and in the correct order. Also all of the cable connections I made on the install as well as connections made at the factory, all were proper and tight.
Bind the RC to the M100 3 or 4 times succesfully.
Reset the Controller, switch from Master to Off, Off to Master, hold C1 and C2 along with both shutter buttons (Video and Still) and turning off and on.
Tried just about every setting on the RC I could think of either off or on depending on what setting. All firmware versions are current.
