R&L Aerial
Flight distance : 298100 ft
The temperature gun is found on harbor freight website also dealt makes one that's a little more expensive. After I finish a flight I use the temperature gun to check each motor and the battery, just point and pull trigger it will tell you temperature of what ever you point it at, then I write the outside temperature and the temperature of each motor on a note pad. This way you can see if one of the motors is starting to show signs of wear. I've noticed on the inspire 1 pro with the x5 the front motors run a few degrees warmer than the rear motors. The old inspire 1 all the motors run about the same temperature. Example yesterday it was 45 degree Fahrenheit outside and when I landed the rear motors where 68 degrees and front motors were 70 degrees Fahrenheit, battery was 65 degrees. I hope this helps. |
