wachiperro
Flight distance : 29209 ft
Chile
The reason you're seeing a blue tint from outdoor lighting is that the camera's white balance (color balance) is adjusted to indoor lighting. If you adjust to outdoor (5600K) then your indoor footage will look orange.
The proper way to correct, and almost impossible unless you have a crew, is to place color correction gels on all the windows so the color temperature for outdoor and indoor match. OR, gel the lights indoors to match the outdoor light. Also, very time-consuming.
I haven't used the Osmo, but if you can dial in the color temperature, try to find a happy medium, possibly around 4200-4500K.
Hope that helps. |
