I still have horizon tilt,anyone else?
956 2 2016-2-5
nigelbrinkmann
Flight distance : 586391 ft
Hi all
I'm still getting this horizon tilting slightly,after starting the Osmo and after sleep mode, I have the latest FW and iOS app updated etc, but I don't think I should have to do a gimble calibration every time I start it up?or do I? It dose come good after around 20 secs or so, which is around the same time to do a calibration,missed a few good shots because of this, if a lot of people have this problem still,maybe a thought for anothe future FW update fix
2016-2-5
DJI-Adela
Hi, seeing from your description, that's not a big issue. I'm afraid you need to calibrate the gimble on occasions since the gimble system is quite sensitive to the surrounding interference. When there's strong vibration and the gimble detects that it's not very stale, it'll always try to make a balance until it's OK, so that may take some time itself. In the future, I believe, our engineers will try to optimize this property.
2016-2-5
nigelbrinkmann
DJI-Adela Posted at 2016-2-6 14:35
Hi, seeing from your description, that's not a big issue. I'm afraid you need to calibrate the gimbl ...
Thanks Adela for your response,Ok maybe in a future FW update.
2016-2-5
