WetDog
Flight distance : 1131886 ft
On the Phantompilots.com site, there is a section devoted to an attempt to hack the P3 firmware. Mostly this started as an attempt to bypass the ill designed Geofence system. I kinda doubt they will get there - although I would love to see it happen - but there are some interesting points being brought up.
In particular, the DJI app is very, very chatty. Both in use and out. Unfortunately, the only way around that at present is to firewall the app. This can be done in Android land but unless you jailbreak, not in Appleville.
If you are worried about the yappy app, check out those threads on particulars. |
