SENDING DJI OSMO FOR REPAIR / 23 FPS = A/v out of sync???
949 7 2016-2-16
EXPO
When you send in "for repairs", what you get in return is a New DJI Osmo . So far so good in terms of capturing data. Have yet to record sound on the Osmo with external mic , but when I was looking at the data behind the videos I noticed that the FPS for a 24FPS file is actually 23FPS????? Could this be the reason that I am seeing a lot of A/V out of sync issues?
23 FPS ?????
23 FPS ?????
2016-2-16
rodAndTheCat
New Zealand
now that is interesting. Comments DJI please.
Rod and the (curious) cat
2016-2-16
DJI-Adela
Hi,
Please try to use another media Player, such as KMPlayer. Different player may display different frame rate value.
2016-2-16
EXPO
This is not from a player , it's from the actual metadata from file itself !
2016-2-17
EXPO
Straight from the card itself
2016-2-17
LenMiddx
Have you tried looking at the video file in QuickTime Player? What does the Inspector say about the frame rate?
As for the video-audio mismatch -- that's caused by the audio drifting, and most people have it regardless of frame rate (here in PAL-land it's 25fps as standard).
2016-2-17
EXPO
LenMiddx Posted at 2016-2-17 10:56
Have you tried looking at the video file in QuickTime Player? What does the Inspector say about the  ...
Ill check that out. Is there anyway to sync the a/v?
2016-2-17
LenMiddx
EXPO Posted at 2016-2-18 06:23
I haven't tried it yet (as I'd rather dji fixed an obvious 'bug' in the Osmo system) but -- and here I stand to be corrected -- if the drift occurs at a fixed rate it should be possible to stretch it in post and also keep the pitch from changing. It depends on your editor, but most modern NLEs should have that facility.
I might try it this weekend (in FCP X) and see how practical it is.
2016-2-18
