agpilot2b
Flight distance : 3852293 ft
New Zealand
I've looked EVERYwhere over the last 2 weeks for a solution to this EXACT problem, and this is a rediculously easy mistake to overlook. As a matter of fact, they make the same mistake in the "Installing Lightbridge 2" tutorial video. (See below)
You see that all 7 pins on that screenshot are not wired...???
With the correct setup, the 7 pin plug that fits into the LB2 is the start of this Y cable and actually has all 7 pins wired. (the root)
This cable then splits into 2 x cables, 1 of them having a can plug on the end, the other having another identical 7 pin plug that fits into the G7 port of the GCU, but only has 5 of the 7 pins wired. (See my little sketch attached)
Get these plugs the wrong way round, and thats when you cant map any other channels... Swap it to the correct way, and BANG... EVERYTHING WORKS.
Hope this helps.
Gareth |
