Jacques850
Flight distance : 3816972 ft
Brazil
Configuration [around US$ 10.000 with all the stuff]:
- Spreading Wings S1000+
- A2
- Lightbridge 2, with CAN-Hub
- Zenmuse Z15-GH4
- DJI Go App 2 version 2.6
- iPad Air 2 iOS 9.2.1
- All firmwares updated to the last version
Questions and issues:
- A2 Flight controller constantly with solid red LED --> Is that correct ?
- On the other side the LED on ground controller is solid green: OK
- Very, very bad quality of video feed = high risk in flying and an enormous frustration --> What the reason of that and how to fix it ?
- Is still iOS the problem ?
- Output EXT with 100% of bandwidth, no external interference and at least 5 meters distance
- GH4 4k output downgraded to 1080p/60
- All connections checked
- Gimbal calibration is not responding nor working --> Why ?
- The DJI GO App HD window, Auto mode: not appearing the possibility of choice between low latency and high quality, as we can check on DJI videos --> Why ?
I will be very grateful if somebody could help and give some orientation or make needed comments.
Heavy user of P3P, Inspire 1 and Pro, till now the experience with this new stuff is absolutely deceiving though very expensive
Thanks you all,
Jacques
