Casey Preston
The resolution that it records at is 1080p. The actual detail in the image is far less. The Osmo uses a crop of the sensor and uses a minimum amount of photosites to get to to the recorded 1080p so that the processor can keep up. The regular 1080p oversamples the sensor. It is similar to the difference one sees when comparing a Canon DSLR to a Canon cinema camera or newer video camera. The sensor crop can also show more problems with the lens since you are using less of the actual lens area. The Osmo is not a particularly sharp camera based on my tests. Also, normal 30p or 25p and 24p encodes at about 40bps. The 120p encodes at around 60bps. It is trying to encode at least four times as much data with about 50% more memory. Finally, because things are moving slower, you tend to notice the lack of detail since there is motion. DJI may also have not added enough sharpening for people's tastes, so you can increase the sharpening in the app to help.
Matt your footage looks right to me, it just also has added diffusion due to the weather. Ohmface's footage also looks like what I would expect.
In the end, it would be better to use 60p and retime in post to get to slow motion unless you absolutely need the slowest footage that you can get. |
