nigelw
Flight distance : 518084 ft
So, explain why hand catching is so stupid. Really, if you're so intelligent you should be able to come up with a good strong argument as to why it's stupid, rather than just your arrogant & unhelpful opinion.
I personally think it's relatively safe if you think about what you're doing & carry out a risk assessment. For example, the blades might cut you or worse, cut you eye(s). An easy way to limit the likelihood of that happening would be to keep it above head level at arms length. If you can't judge the distance between the legs & the props you probably shouldn't be flying in the first place. As for trying to control the drone, once it's hovering you can easily judge how stable it is & normally it's very stable. If it wasn't we'd all be taking off & landing with much greater distances between ourselves & the aircraft. There's no controlling to do. |
