SVTRay
If you're using an older firmware, not sure which, you can simply get the bird up to 500m. Once you get the max altitude warning, hold the RTH button and then press up on the ascend stick. This has since been eliminated with recent firmware updates however.
Other than that, you could pick up an older Phantom 1 or 2 which is what people on youtube are using to get 3,000-7,000 ft. You can install a 4k Go Pro...Go Pro is also suspected of releasing an 8k Go Pro camera near the end of the year.
