marcsobel
In an attempt to update the Inspire 1 and two remote controllers, One of my remotes is now bricked.
The attempt was to install Remote control version 1.5.80, Camera 1.7.00.90 with master download version 1.6.00.40, using Droid DJI GO 2.7.0
When starting the Droid app, the update required displayed and when to do the upgrade, downloaded the file and then installed the software, at the end a message said the update failed. From this point on the controller will not do anything.
Tried the following:
Using IPad instead of Android (both have current IO and app software)
Tried factory recommended controller reboot using 4 button push with turning the controller on and off.
Tried default version gs_ofdm.bin on USB, EFAT and FAT formats
Tried current version WM610_FW_V01.07.00.90.bin on USB, EFAT and FAT formats
Tried to connect with camera gimbal via cable, old method.
Tried manual link with Inspire1
Tried reinstalling Android and IPAD app and reconnect.
The results are all the same, the controller displays a bluish led, not green or red.
The App says the controller is disconnected, will not show versions on the "about" screen, shows N/A
The Application do not show a prompt to update.
My other controller works just fine, used the same process to update, originally the bricked controller was set as the master. My slave have been moved to be the Master now and it flys the Inspire 1 just fine.
Any more ideas would be welcome,
Thanks |
