Phantom 3/4 Range and Channel Information
17810 20 2016-3-23
Mad_Angler1
Flight distance : 2741657 ft
With some of the reports going around I have been having a think and have some suggestions for folks to try if your suffering from poor range. Whilst there have been many changes to the power outputs cross all of DJI craft none of these would result in large differences in flight distance some people are seeing, in fact the Phantom 4 has more output than the last revision of the Phantom 3 so this rules out it being related to that, also what is often forgotten is that the CE region output is about 75% less power than FCC and we are still able to achieve long range results and comparable distance to FCC areas.
To be clear I am not saying some folks are not having issues I just don’t believe any output changes are the cause.
Antenna Orientation
First of all make sure you understand correct antenna orientation
See DJI tutorial below
Next look at your flight environment, Lightbridge is on 2.4Ghz and although it’s a strong link WiFi congested areas will have a large impact on range there are some things you can do to try and get around this.
Look at the HD menu below and see if your getting interference or connection
Clear channels are signified by a Green Bar
Channels in Use or that have interference will show with a Red Bar
Your current channel will show with a Blue Bar
Manual Channel Selection
Next try selecting a clear channel manually by using Custom Channel in DJI Go
Note: if your in the UK or some other countries DJI go will not allow you to select Custom Channels, Change your devices region to USA and the option will now work.
Go to Image Transmission Settings in the main menu and select the HD menu
Change Channel Mode to Custom and select a clear channel, you looking for one with a green bar showing its stable, ideally try ch16 if its clear.
Set Transmission Quality to 4Mbps
Test now, If its still no better try the following.
Expand to 32 Channels
This is a channel expansion mod that allows you to select all 32 channels instead of the 8 normal ones available to you and other WiFi devices, this means you can put your connection on a channel thats less likely to be in use no matter where you are, once you have done this follow the process above but this time select a clear channel well out the way of the normal 13-20
Download the Files Here, this file is zipped up and will need to be unzipped.
https://www.dropbox.com/s/yuilvt ... fig%20File.rar?dl=0
Android
Connect your Android device to your computer
Download the attached file DJI.configs
Copy the config file to the root directory of \Android\data\dji.pilot\files
Launch the DJI Go app and you will see that the remote controller now shows support for 32 channels.
iOS
Connect your device to iTunes on your computer
Click ‘Add File’ and copy the file to DJI Go Documents
Launch the app and you should now have the 32 channels available.
Again Note if your in the UK or some other countries DJI go will not allow you to select Custom Channels, Change your devices region to USA the option will now work.
Once you have done this as posted try selecting a clear channels well up the band away from the normal 8 again looking to avoid channels with red bars or are surrounded by red bars, then set Transmission Quality to 4Mbps, you may need to try multiple channels before you find one that’s gives best performance.
DJI Go App
Signal issues can be related to the tablet overheating, Make sure you keep it out of its case and its keep as cool as possible before use, use a sunshade if you can.
Also try with a different device if you have one available.
Comparing 2 Craft
If your comparing 2 craft like the P3 and P4 and are finding the range of the P4 is substantially less than the P3 try the following.
1: Set both craft on custom and select CH16 if clear and set both to the 4Mbps bit rate, Test one craft at a time with the other turned off completely, both controller and craft not in use must be off.
2: If still substantially different try the same but test on 3 separate channels, Bottom, Middle and Top of the channel band and look at the results.
3:  Try binding your P3 or Inspire Controller to the P4 and test again as above.
Overall even two identical craft may have slight differences in range, there are many factors that can affect the range of one over another even being tested at the same time.
2016-3-23
dirter
Flight distance : 3633799 ft
This is one of those questions that will eventually answer itself but, do the added channels get wiped out when the app gets updated? Just curious if I should keep the config file for reloading.
2016-3-25
Old Geezer
Flight distance : 23691 ft
Thanks for that Mad Angler - I'm not having the problem but will try it out in case I ever do
2016-3-25
p.robinson6
Flight distance : 21657 ft
Old Geezer Posted at 2016-3-25 12:52
:hand ...
i am new to the DJI 3  Drone so hope you forgive me if this is a stupid question .
Will this only work if i have my tablet region set to USA rather than UK ?
2016-3-31
p.robinson6
:hand ...
Will this only work if I set my region to USA ?
or can i have it set to UK ?
2016-3-31
Old Geezer
p.robinson6 Posted at 2016-3-31 13:36
Dunno - you'll have to ask MadAngler ... my P3A is waiting return authorisation after it fell out of the sky, and I don't want to change anything before it goes back for inspection and repair.
2016-4-1
Jbundy63
Flight distance : 9583182 ft
dirter@frontier Posted at 2016-3-25 19:29
This is one of those questions that will eventually answer itself but, do the added channels get wip ...
I have the 32 channel installed on both my P3P and P4 and it has stayed on every update that I have done, but doesn't hurt to k people it on file.
2016-4-1
Mad_Angler1
You have to set your device region to USA if in the uk otherwise you won't be able to select the Custom channel option at all.
2016-4-1
Arvada
Flight distance : 398822 ft
I downloaded the RAR file and extracted it.  It gives me a config "folder" that is empty.  Am I doing something wrong?
2016-4-9
bernidenina
Flight distance : 8799 ft
Arvada Posted at 2016-4-9 06:52
I downloaded the RAR file and extracted it.  It gives me a config "folder" that is empty.  Am I doin ...
i got the same thing
2016-4-10
kkaranta
Flight distance : 180883 ft
Greece
Arvada Posted at 2016-4-9 16:52
I think you check "show hidden files" and then you will see the config file.
2016-4-11
Murilo Carmello
Flight distance : 1562549 ft
Brazil
32 channels now for me
tks a lot
2016-4-20
Arvada
Yes, I love apple but forget that they really like to lock things down.  You were correct.  For iOS, unhide those sneaky little files.  Works like a charm.
2016-4-23
roberto-lenci9
Mad_Angler1 Posted at 2016-4-2 01:39
You have to set your device region to USA if in the uk otherwise you won't be able to select the Cus ...
yes, but I arrived at this conclusion after replaced the original DJI antenna with WIFI panels 7dbi, model: IA-7PA.
Now please could you tell us the procedure to change the device region to USA?
2016-7-9
roberto-lenci9
Murilo Carmello Posted at 2016-4-20 23:07
tks a lot
hallo Murilo, did you have to change the region on your device to have 32 channels in Brasil?
2016-7-9
Murilo Carmello
Brazil
roberto-lenci9 Posted at 2016-7-9 17:18
No, I just follow the instructions above
2016-7-9
boss
Denmark
How do I change the country settings so that I can select channels myself.
2016-8-12
boss
Denmark
HOW???
2016-8-14
boss
Denmark
How do I do that ??
2016-8-14
razrdan
You need to connect to your AC and RC via telnet. Then type the command,
iw reg set US
This will set the region to USA, along with the associated FCC regulations. This must be done on both the AC and RC. You can check the country and power regulations by typing the command,
iw reg get
You can also check the TXPOWER by typing,
iwinfo
You can then type this command for good measure,
iw dev wlan0 set txpower auto
2016-10-3
chrisguk
Czechia
Anywhere to get these files now? The link is broken.
2017-12-3
