david.p.mann
Flight distance : 18669501 ft
I have tested the maximum range of the Phantom 4 RC/aircraft control and HD video downlink (DJI Lightbridge) several times in the past week and achieved 4+ miles! Frankly, I was not able to find true max. signal range because I would reach what I felt was minimum safe battery level to return all the home and still had 4 bars RC signal and HD video link.
As shown in the flight log screen grabs below, I was able to reach 23,650 feet (4.5 miles) on first test flight and 20,900 feet (4.0 miles) on second test flight before deciding to turn the P4 around and bring it home. Battery levels were 62% and 68%, respectively, at the max. distance turnaround point. Please note these tests were conducted flying over mostly unpopulated farmland with no trees, buildings or landscape obstructions for at least several thousand feet. I flew in P mode with obstacle detection turned off, which I call P-Fast mode (38 mph max speed). I could fly further, I suppose, if I only flew one way, but I like to bring my P4 all the way back to home point with 10-20% battery capacity remaining.
Here's the setup I use for reliable RC and HD Link connections out to 4+ miles:
1) On HD page Select Custom channel and watch interference plot for several minutes; choose channel with lowest signal levels and no intermittent signal spikes (I choose Channel 20 90+ % of the time).
2) On HD page, set Transmission rate at minimum (4 Mbps); this will maximize your HD Link range (this is critical)
3) RC set to P-mode so you have full GPS functionality
4) On Sensor page, turn OFF obstacle avoidance. This will increase max. horizontal speed from 20 mph to to 38 mph. This will facilitate max. distance possible on a battery charge.
5) Two Antenna should be nearly vertical at whatever angle you normally hold the RC in your hands. The two antenna should be parallel to one another with wide flat sides facing the P4 at all times.
6) I use one simple, inexpensive ($30) third-party add-on to improve signal strength and range - it is a well-made aluminum parabolic reflector sold by a NJ (edited) eBay vendor that easily slips over the two upright antenna. The perfectly shaped curved aluminum reflectors, which are behind the antenna, reflect and focus incoming HD video and telemetry signals coming from the P4 aircraft on the two antenna.
7) Continuously readjust (or hold body position steady) as needed throughout the flight to keep antenna aimed directly at P4.
8) ALWAYS start with a fully-charged battery.
23,650 Feet Max Distance Flight
20,900 Feet Max Distance Flight
