Hello, I have a problem with the firmware upgrade to Phantom 4.
The Phantom 4 worked perfectly before the firmware attempt.
After the update failed several times (about 20x), I did a factory reset.
I use three Dji Assistant 2 versions.
In the older version for Phantom 4 I get two firmware versions.
The version V02.00.0700 (New) is downloaded to 98%, then the upgrade starts on the threats and always breaks between 1 and 8%.
The version V02.00.0106 is down to 96% downloaded, then the upgrade starts on the threat and always breaks off between 1 and 8%.
The version which is normally used for the Mavic Air downloads the update to 100%, Trasmission is also 100%, Updating remains stuck at 20%.
The other newer Dji Assistant 2 for Phantom 4 version only displays "Can not Load Firmware List. Please Retry".
In the Dji Go4 app on Samsung Galaxy S8 I have since the factory reset no more access to the drone.
Many Thanks!
Obermair Norbert
