DJI GO App not working on iPad Air 2 iOS 9.3.1
fuji27
Trinidad and Tobago
Just purchased an iPad Air 2 and it has iOS 9.3.1 installed. The DJI GO app only shows the "How to Connect" screen for my Phantom 3 Pro,
but does not connect.
The DJI GO app works fine on my iPhone 6 Plus with iOS 8.4.1 installed.
Please help.
The reason why I purchased the iPad Air 2 was so I could utilize a bigger screen when flying.
The iPad Air 2 is supposed to be supported.
I have no other programs installed on the iPad, just the iOS and the DJI GO app.
Again please help solve this problem, thanks.
2016-4-3
sandmarkcontrac
Hi, I'm having the same problems, I purchased a iPad Air 2 for the same reasons, It worked fine until I just updated the firmware of the Aircraft, controller and Go app to the current versions.
I also updated the iPad to version 9.3.1.
It now wont let me see the camera on the screen.
Mine still works on my Sony phone (small screen)  but the iPads a no go.
Was intermittent before , now its a paperweight.
Hopefully Dji will sort out some firmware issues.
2016-4-3
Kit Walker
I think it was the new DJI GO app that was the problem for me. It had trouble communicating with my Inspire 1 remote.., but worked fine after updating RC firmware.
2016-4-4
RichJ53
Flight distance : 1837356 ft
Try uninstall and reinstall the Go App and see if this works
Rich
2016-4-4
manuelnegronpr
Flight distance : 10933205 ft
Puerto Rico
My two cents. I have the iPad air 2 with version 9.3.1 and everything working perfect. Sorry for your communication issue. Hope you can fix it.
2016-4-4
DJI-Paladin
Flight distance : 2408 ft
Hello, I'd suggest you to reinstall the DJI GO APP and change other apple original lightning cables again. What's more,  you can erase your all content and settings in your air 2 and then reinstall the DJI GO APP .
2016-4-5
RedHotPoker
Flight distance : 165105 ft
Nary uno problemo minuscule... Hahaha
Nothing to report, but broad smiles, señor.
RedHotPoker
2016-4-5
gregorum
Flight distance : 613241 ft
same here. Updated my Iphone 6 + to 9.3.1 and dji go app doesn't connect(tried to delete/soft reset/reinstall nothing) tried 3 different cables, nothing. Installed djo go app on wife's iphone 6+ ios 9.3.0 and it connects perfectly
2016-4-6
Kit Walker
Is it possible to try an older version of DJI GO app?
2016-4-6
daveabbey
Flight distance : 10325 ft
Kit Walker Posted at 2016-4-6 22:16
i have the same problem with my samsung tab after the last update.. alot of people having same problem.. i just read that you should reinstall the RC and Bird firmware.. i havent had time to try but will tomorrow.. maybe that will do it
2016-4-6
sandmarkcontrac
Ive reset my iPad air2 back to factory settings.
Reinstalled the DJI Go app.version 2.7.1
I have the bird on 1.7.6
RC on version 1.5.8
My iPad version is now 9.3.1
Now Ive made it worse, the App wont connect at all, before I couldnt see an camera feed on the screen.
2016-4-6
sandmark
Plugged in my Sony Xperia phone with Dji Go app and it will show the main screen with the controls etc but will only show the camera image one in 10 times.
iPad air 2 will not connect, swapped with brand new apple leads etc (its not a lead)
2016-4-6
Kit Walker
I had two different problems. DJI GO would not "Connect to aircraft" (written in green above "Enter Camera")
Sometimes it would say "How to connect", or "Camera".., but I still had no FPV, telemetrics etc.
Try this thread. http://forum.dji.com/thread-46662-1-1.html
2016-4-7
fredkusin
I have the same problem. Works fine on my iPhone 5s with 9.3.1, but my iPad 3 mini 9.3.1 cannot connect to the "Camera". What's weird is that my iPad let's me LOGIN under the "Me" icon, but my profile doesn't show my Flight Records and other profile info.
2016-4-13
Daninho
Flight distance : 70203 ft
I reported about this problem a month ago, shows always how to connect on both iphone6+ and ipad air 2. I sent my remote controller in for an FW update and USB Port check. Lets see
2016-4-13
Pilot370
I had same issue with my iPad Pro 9.7. It was on 9.3.1, so i returned it to Best Buy. The new one had 9.3 on it, i left it at that and it all works fine now.
2016-4-13
knupla2
Flight distance : 922 ft
Pilot370 Posted at 2016-4-13 11:12
I had same issue with my iPad Pro 9.7. It was on 9.3.1, so i returned it to Best Buy. The new one ha ...
Something is sure odd about this.
My Air 2 is on 9.3.1 and works perfectly.
That said, I can't stop complaining about how poor the Air 2 is in sunlight.  Terrible.
ADDED:  BTW, there is an update to iOS 9.3.1 that fixes an issue wiht apps that become unresponsive .  Try updates.
2016-4-13
Donnie
Flight distance : 3636782 ft
knupla2 Posted at 2016-4-13 13:08
Where did you find this fix at ?
Thanks- donnie
2016-4-13
knupla2
Tip: The post by the administrator or moderators shield
2016-4-13
knupla2
Not sure why but it looks like my post got locked
2016-4-13
knupla2
Donnie Posted at 2016-4-13 12:25
Thanks- donnie
email me at steve@nmpcs.com
2016-4-13
fredkusin
fredkusin Posted at 2016-4-14 00:15
I have the same problem. Works fine on my iPhone 5s with 9.3.1, but my iPad 3 mini 9.3.1 cannot conn ...
Fixed. Download Apple Beta 9.3.2 and install on your IOS device.
2016-4-13
bmartosb
Just did the same, problem solved!! Please refer to "Compatibility between ipad pro and p4. Bobreich explained in detail how to do it
2016-4-13
cagareli
Georgia
Hello all,
I have same problem, I have Ipad Air2, 4G version, with SIM card.  DJI GO not working. because IOS 9.3.1 is not posible for DJI GO.
maybe DJI will answer us, when this problem will corrected?
!!! DJI - maybe better, if all of us will sell our Ipads?
2016-4-14
Richard in Bois
Flight distance : 34721 ft
cagareli@gmail. Posted at 2016-4-14 21:20
Hello all,
I have same problem, I have Ipad Air2, 4G version, with SIM card.  DJI GO not working. b ...
I also have ipad air 2 and it works fine.  After installing latest ios update, I deleted DJI Go app and reinstalled and all is fine.
2016-4-14
Daninho
Richard in Bois Posted at 2016-4-14 21:26
I also have ipad air 2 and it works fine.  After installing latest ios update, I deleted DJI Go ap ...
most ppl did that without success, this is not the solution. I guess you need the latest remote controller FW
2016-4-14
0722
Norway
I have just replaced an old samsung Tablet, which was just able to run DJI go, with an iPad Air 2 cellular running iOS 9.3.1 and could not get it to work despite spending hours trying out all the tricks (re-install, reset to factory settings etc). Following the lead of some others I upgraded my iPad Air 2 today to iOS 9.3.2 beta, which came out about a week ago. Now everything works perfectly.
2016-4-14
Daninho
0722 Posted at 2016-4-15 00:29
I have just replaced an old samsung Tablet, which was just able to run DJI go, with an iPad Air 2 ce ...
Did you tried the latest remote controller FW ? I have an ipad air2 with 9.3.1 and it works after i send my remote controller back to DJI for repair. They switched replaced the controller with the "C" version and installed the latest FW. Now it works with my ipad air 2 on 9.3.1
2016-4-14
ljdeangelis
I can confirm that joining the Apple Beta program (It's free - google it) and installing Public Beta 9.3.2 does indeed fix the DJIGO 'How to Connect' problem. After the 9.3.2 beta upgrade the Phantom 3 connects fine.
2016-4-14
0722
Norway
You actually do not have to join the Apple beta program to download Beta 9.3.2. There are some sites that provide the download, for example, https://www.reddit.com/r/iOSBeta/wiki/dl
2016-4-15
Tdobbins
Same problem , chatted with DJI help desk they have confirmed they have problems with IOS 9.3.1
Pain wish I hadn't upgraded the software ,     Help desk advises no idea when it's going to be fixed, !!
2016-4-17
