lido_bmt
Flight distance : 87772 ft
For pretty much any of the modes I'll make a rough estimate ahead of time by drawing it out on the map and setting estimated parameters. When I get to where I'm going to film I'll then run the flight plan in Joystick mode, meaning that I can completely control the speed the P3 flies on a path: no input on the left stick will have it hover, pushing up on the stick will move it forward on the path until it reaches max speed when fully engaged. Pulling back on the stick will reverse direction and increase the reverse speed the further back you pull on it. This way I can see both the point of view of the camera as well as make adjustments to the flight plan – altitude, direction, speeds, focus points, etc. You can both move points directly on your tablet (I don't recommend using this on a smaller iPhone) or use remote control overrides to move the P3 where you want it and set things that way. Doing this also guarantees you'll never fly into anything since you're basically doing a test run at a completely controllable rate.
As for adjusting yaw rates and interpolation, that's fairly easy once you understand how the focus points work. There are basic interpolation methods that dictate how fast you switch focus points (these are called focus triggers), but if you want to really fine grain how fast or slow you interpolate between triggers it's simple – you just add intermediate points. You can also set it to not interpolate at all when you don't want it to and it will snap focus as fast as possible, which can make for some interesting effects like snap pans.
It sounds more complex than it actually is once you start using it. |
