rbendjebar
Flight distance : 3170190 ft
Apparently DJI has decided to frame the stills in a 16:9 format, same as HD TV, rather than the 35 mm standard 3:2 format, or the form factor of the Exmor sensor, which is 4:3. Maybe that has to do with processing time for the CPU, or some other limitation, but it does not use the full frame of the sensor, as you noted. |
