Hi,
If it's still under our warranty, I would recommend returning it for repair. Unfortunately, we don't sale the inner battery of LightBridge 1 separately.
Hi,
Same thing appended. apparently due to very low level in cold condition. At least it was under warranty.
Nevertheless it is easy to open the ligthbride ground and replace battery.
Hi Skyguide
Did your Lightbridge work ok after the battery replacement or did you have problems with the firmware being lost ? The reason I ask is a lot of people have had problems where the firmware is not visible after a period of storage. Just wondering if the new battery would have solved their problems is all. Also are you still flying with the lightbridge 1?
Thats good to hear. How long did it take to change out the battery? Sorry for all the questions? I am just trying to establish why the light bridge units are failing when stored for a period of time. I purchased a unit 2-weeks ago and the ground unit battery was completely flat. Updating the firmware would not work(it has been sent back to the supplier). After reading on the forum I have found that this is a common problem and it appears that DJI are not addressing it.
