Retaining Osmo gimbal settings for C1 & C2
618 4 2016-4-20 14:25:25
jeff
Beginner
How can I set custom gimbal settings for C1 and C2 so it remembers it? I'm assuming it should retain the settings you make for C1 and C2 but everytime I program all my gimbal settings in C1 it never retains what I just programed when I push Done and go to Med or Slow. When I go back to C1 none of my settings are there.
2016-4-20 14:25:25
DJI-Adela
Hi,
The Gimbal Profiles: Fast/Medium/Slow are all fixed settings. When you customize the C1/C2 settings, select the wanted values and click save, it will come to effect immediately. Next time, if you wanna activate your settings in C1 or C2, you need to select the C1 or C1 profiles you've set before. Please set the "SmoothTrack Settings"/"SmoothTrack Adjustments"/"Joystick" in "Advanced" properly.
If you have any other problem, please let me know.
2016-4-20 18:41:33
info961
Beginner
Hi DJi-Adela, I have the same problem of Jeff, I tried to setting the C1 and C2, but when i came back to the other settings (medium ecc.), the C1 and C2 setting do not remain stored, I tried a lot of time, save and done, but nothing. I have a Osmo DJI X3, with last firmware connected with iPhone 6. Let me How can I store the settings. Thanks
2016-8-5 03:20:18
Tom899
Beginner
info961 Posted at 2016-8-5 03:20
I have this same issue with my new Osmo+. My C1 and C2 settings won't save. They stick as long as I don't touch them, but as soon as I go to another setting such as Fast Medium or Slow, and come back to C1 or C2 they are gone?
2017-4-19 04:11:13
Tom899
Beginner
Well, I found out why this is happening. I have a smaller screen device, iPod touch 6th generation, same size as Iphone se. To click the save button you have to scroll up and the field you are changing is not in view anymore, and it doesn't get saved. If I put the iPod in portrait mode where you can see both the field and save button it saves it. So I think this is a bug that only effects smaller devices.
2017-4-19 08:36:58
Close
DJI RecommendsPrevious /1 Next
