Donnie
Flight distance : 3636782 ft
Check and see if the VPS wiring harness is plugged in firmly to the aircraft, it is a balck wiring harness , kind of hard to see, look carefully. Make sure it is seated in the module, it may have not been plugged in correctly at the factory or came loose in shipping. ( It is just in front of the battery pack, you will see it )
If that is loose or not plugged in ,of course just plug it in . If not then tDJI will more than likely have you send it in for repair.
****Make sure the sensor is clean as well, no tape or anything covering the sensor.
Glad we at least know it is not working . ( The cause )
donnie
donnie |
