Can't Calibrate Compass After Update
2331 7 2015-1-15
huffmd1
I have updated my Inspire 1 and the remote with it.  After updating I did an advanced updated on the IMU. After this I cannot calibrate the compass?? Any ideas anyone?
2015-1-15
mlglisson
Flight distance : 7782 ft
you gotta be kidding
2015-1-16
markwchoate
Two days ago received and unboxed my new Inspire.  Performed firmware update on Inspire and remote.  Then calibrated compass.  All went perfectly.  Initial flights smooth, perfect.  I have not performed that advanced IMU update.
Hope this helps.
2015-1-16
marcfrdly
I had a similar experience after I upgraded yesterday. After upgrading the craft I got an immediate compass error. I did an advanced calibration, compass showed 240, everything else was perfect. I cut the craft off, restarted, same thing., compass error at startup. Attempted to calibrate, and process would hang up during nose down calibration. I was doing this near a wall inside, and the wall has metal studs, so I moved it into a area away from any possible interference, restarted the craft and was able to calibrate the compass. I then did an advanced imu and all was right were it should be. I have not flown it though, as I am waiting on the prop guards, but have had 10 flights before this and Inspire performed well.
2015-1-16
DJI-Dboy
China
Hi,
Does "advanced updated on the IMU" you said is actually IMU calibration? Because IMU cannot upgrade individually.
I think you shall follow above post's instructions, maybe your calibration environment has an EMC interference which lead the failure.
2015-1-17
airymok
Flight distance : 2623652 ft
China
latest firmware gets more critical standard to ur calibration environment. Stay at home to calibrate can't success. Try to go out.
2015-1-17
huffmd1
I have been trying it indoors.  I will have to go outdoors and try it again.  Still can't fly right now because I am waiting on new props.  I was having problems with mine drifting when I first got it which is what this latest firmware update was supposed to fix.  Thanks for the advices guys.  I will keep you posted.
2015-1-19
The Colonel
Looks like more firmware updates are coming hope its sooner than later .
Only issue I had was a lock up during the firmware install. IMU and compass both calibrated perfectly and all says ready to fly even check the compass values all looks good .
Man this is disheartening to hear let us know what you find out OP
2015-1-19
