Phantom 4 just fell out of the sky
12Next >
4415 48 2016-4-22
kkdji
Good Day,
I have bought a DJI Phantom 4 and after 2 days of flying (1:04 hours) the Phantom fell out of the sky.
I was flying when the Phantom 4 started to climb to 177meters while the max altitute was set to 120m. I tried to lower the phantom manually but it didn't respond. After a few seconds the phantom just fell out of the sky.
In the log i see it is climbing to 177 m. It get's warning that max altitude mode is activated but whatever i did it kept climbing. When it reaches 177 m it is starting to lower till 164m and then the log ends. I think the software has crashed there and the phantom then starts to fall. It fell 164 meters.
What can be the cause of this and how is this solvable?
Thanks
2016-4-22
Hawks100
Flight distance : 134580 ft
Sorry for your loss.
It sounds like your P4 is going to be toast after falling 164m.
Have you contacted DJI ??
2016-4-22
kkdji
It fell on the grass so the body cracked, gimball is nog working and i think there is more damage.
2016-4-22
kkdji
kkdji Posted at 2016-4-22 20:52
I also just contacted dji but because i live in the Netherlands i don't know what will happen
2016-4-22
sploodge
Flight distance : 809350 ft
Contact DJI and post logs here for others to look at..
https://healthydrones.com/
2016-4-22
kkdji
How do i get my logs uploaded to the site? Where are the logs located?
2016-4-22
sploodge
2016-4-22
kkdji
If i connect my ipad to my pc i have to set it up as a new device.
The only thing that is installed on my ipad is the DJI Go app.
Can i configure it as a new device, install DJI Go again, login and see the log files?
Or are they stored at the ipad?
2016-4-22
sploodge
kkdji Posted at 2016-4-22 20:04
The only thing that is installed  ...
The configure as new device only means setting it up in iTunes.. it will not delete anything..
2016-4-22
kkdji
I have uploaded it to healthydrones.com, how do i share it?
2016-4-22
Alan Guan
Banned
2016-4-22
kkdji
I set the limit to 120m and when it started climbing i tried to bring it home but it didn't respond
I was flying at max 60m but it climbed by itself (i didn't do that)
Battery was full when i started and when it crashed it had 63% left
2016-4-22
kkdji
http://healthydrones.com/main?share=UlRTet
2016-4-22
microcyb
Flight distance : 1095955 ft
kkdji Posted at 2016-4-22 15:51
Yeah, that looks like a fault with the DJI.
You should get a ticket created http://www.dji.com/support/product/phantom-4
2016-4-22
kkdji
I thought so to because i didn't do anything strange with it
2016-4-22
joey.lopina
Flight distance : 498839 ft
RIP.  SORRY FOR YOUR LOSS.
2016-4-22
mark.mwilliams7
Flight distance : 1235738 ft
From the log you got three warnings then it went of on a waypoint mission to 187ft, did you do see these warning on the device? Switching into atti mode may of stop it flying off!
There may be some other users on the forum that could go a bit more in depth and see more
2016-4-22
kkdji
When it started climbing i tried to stop waypoints and lower the phantom, but nothing happened and a few seconds later it dropped to the floor. I didn't change a mode, it must have done it by itself
2016-4-22
labroides
Flight distance : 9991457 ft
HealthyDrones only gives a brief summary and in this case it doesn't give any clues as to what actually happened.
You might do better to go to http://www.phantomhelp.com/LogViewer/Upload/
Follow the instructions to upload your flight record.
Come back and post a link to the report it provides
2016-4-22
Alan Guan
Banned
2016-4-22
DJI-Paladin
Flight distance : 2408 ft
Sorry for your loss. I'd suggest you to upload your flight record and then contact our service center in Europe as below. We will look into your case when you send your drone back:
Email: support.eu@dji.com
Phone:+49(0)97479304200
Monday to Friday, 9:00AM-5:00PM (German Time GMT+1:00)
Online Support:Monday to Friday, 11:00AM-6:00PM (Netherlands Time UTC/GMT +1)
2016-4-22
kkdji
DJI-Paladin Posted at 2016-4-23 08:32
Sorry for your loss. I'd suggest you to upload your flight record and then contact our service cente ...
Thank you,
I tried to send a mail to that email but get the next email error:
"This is an automatically generated Delivery Status Notification.
Delivery to the following recipients failed.
      support.eu@dji.com"
I used the contact form on the website so i hope that one could be delivered. I will call on monday
Thanks again
2016-4-22
kkdji
I just uploaded the flight plan. I'm a software developer and if i see the log i can only get one conclusion. In the NaviGo it's climbing to much (above my 120m max altitude setting). I then canceled the NaviGo and tried to manualy lower the Phantom. A few seconds later the log stopped. I think the software fully crashed and the complete drone stopped working?
Link: http://www.phantomhelp.com/LogViewer/W2JNTVR9RDDDSLC0DA0R/
2016-4-22
patou72
Flight distance : 3316614 ft
Strange behavior of your AC...Sorry for your loss.
I was wondering why do you have this in the flight log's:
   1m 37.9s        P-GPS        17satellites        26.6ft        0mph        17.9ft        91%        16.121V        4.034V        4.039V        4.025V        4.023V        0.016V        Aircraft lower than the minimum altitude of 3.0m.
   2m 28.5s        P-GPS        17satellites        45.3ft        0mph        212.8ft        88%        15.957V        3.991V        4V        3.986V        3.98V        0.02V                Aircraft lower than the minimum altitude of 3.0m.
- You are at 26.6ft and 45.3ft but you have warning saying that the Aircraft is lower than the minimum altitude of 3.0m (=9.84ft). Maybe there's a glitch in the software or a malfunction in the Barometer.
- You can see also at least 2 warnings (Waypoint altitude is below 10m/32ft) but in this moment you are in "P-GPS" Mode and not in "Navi go".
I think it's a regrettable lost due to a Hard or Software malfunction.
2016-4-23
SajidShah
Flight distance : 627539 ft
Portugal
26 warnings
A        01m 19s        0.0 ft        0 ft        Mode        Mode changed to GPS_Atti
g        08m 07s        504.9 ft        10 ft        Mode        Mode changed to GPS_Atti
SORRY For Yours Loss Mate
2016-4-23
FatedFilmsNC
kkdji Posted at 2016-4-23 03:58
I just uploaded the flight plan. I'm a software developer and if i see the log i can only get one co ...
I see it says your Max battery temp is 112.9 degrees F.  The battery's specs say that it is safe to operate up to 104 degrees F. Your battery may have overheated, effectively killing it and thus, dropping your bird from the sky.
2016-4-23
rodger
Flight distance : 20145135 ft
kkdji Posted at 2016-4-22 15:04
You don't have Wi-Fi on your iPad?
2016-4-23
rodger
You should plan on getting it back to DJI so they can examine the electronics. It doesn't look or sound like pilot error.
2016-4-23
kkdji
I do have Wi-Fi on my ipad and also figured out how to upload the flight logs.
The battery i used during the flight is a brand new battery. The health is 100% and it is charged once. The weather outside was about 14 degrees celsius.
I didn't get any battery warning and the battery information within the app said and still says everything is OK.
Besides that the phantom started to climb above the max altitude level and wasn't responding to the controller.
2016-4-23
Aardvark
Flight distance : 384432 ft
What happened to the record on phantomhelp which starts at 1 minute and 19 seconds. The first three entries 1:19.6 - 1:19.8 seem to indicate major power problems ?
2016-4-23
kkdji
Isn't that just the startup of the Phantom?
Because it is onlye for a few miliseconds and then returns to normal values?
2016-4-23
J.N
Flight distance : 102333 ft
I agree with FATED FILMS battery heating is the provable cause. Very sorry for your lost KKdji, keep us informed about  wow DJI go to deal with the problem. Good luck. Cheers
2016-4-23
Aardvark
kkdji Posted at 2016-4-23 18:21
Because it is onlye for a few miliseconds and then retur ...
That's what I wanted to find out, but the first 1 minute and 18 seconds of record is missing ?
2016-4-23
Aardvark
FatedFilmsNC Posted at 2016-4-23 11:00
I see it says your Max battery temp is 112.9 degrees F.  The battery's specs say that it is safe t ...
The battery specification refers to the ambient air temperature not the battery core temperature, mine operated at 112f (core temp') without any problems.
2016-4-23
ArtistFirst
Flight distance : 986716 ft
Sorry bro.
Is it just me or is this almost obviously a bad calibration issue.  Bird thought it was going somewhere else, especially coupled with the bad altitude info???
2016-4-23
kkdji
I calibrated the Phantom before the flight. It did fly good till that point
2016-4-23
labroides
SajidShah Posted at 2016-4-23 19:23
26 warnings
A        01m 19s        0.0 ft        0 ft        Mode        Mode changed to GPS_Atti  ...
The HD "warnings" aren't warnings.
They are notifications.
Most are informing that the  Phantom is on a waypoint mission and the two you mention are advising that the Phantom is no longer in waypoint mode but is now in P or GPS mode.
GPS_Atti is the way that is shown in HD
2016-4-23
labroides
ArtistFirst Posted at 2016-4-24 07:07
Sorry bro.
Is it just me or is this almost obviously a bad calibration issue.  Bird thought it was  ...
Looks like it's just you.
The course flown has several long perfectly straight sections.
The characteristic of a poor compass calibration is the inability to fly straight and instead making curves and spirals when straight flight  is attempted.
2016-4-23
labroides
The flight data doesn't point to an obvious cause but it shows what the problem is and helps eliminate several things that have been guessed at.
The key points I note are that the P4 climbed past the max altitude set at 7:51 while in a waypoint mission.
It recognised the altitude limit but kept climbing.
AT 8:08 the mode switched from the waypoint mission to P-GPS and it under normal circumstances it should have been possible to bring it back from there.
A complicating factor would have been that the P4 was almost straight up more than 500 ft  above home point so it  would have been difficult  to maintain good signal at this angle - but if signal was broken, the Phantom should have hovered in place and not continued  to climb.
However it kept climbing until 8:20 @583 feet.
The flight  record ends 3.6 seconds later with the Phantom having descended under power at 3.5 m/sec.
I can't tell what commands were being given and how the  Phantom responded (or not) but comparison with the Go app playback would show this.
This all looks suspicious enough that I believe it's a case for DJI to deal with.
I don't see signs of any obvious operator error in the material available.
DJI will be able to access the "black box recorder" in the Phantom and see more than is visible to us.
I hope they  are able to resolve this for you.
2016-4-23
sivaneswaran.sa
Flight distance : 339888 ft
If u do the startup sequence by pushing both stick together while in sky does the motor stops?
2016-4-24
12Next >
