AERIAL IMAGING EVOLVED
3122 10 2016-4-26
DJI-CS
Get ready to experience the wonder of RAW. The Zenmuse X5R is the world’s first Micro Four Thirds aerial camera capable of recording lossless 4K videos in 12-bit RAW. With a frame rate of up to 30fps and 1.7Gbps average bitrate (2.4Gbps maximum bitrate), the X5R empowers you to capture breathtaking professional-level footage every time. All of this data allows filmmakers to correct errors in shooting, push and pull highlights and shadows and color grade to create the exact look and feel they need for their shot.
Packed with a powerful MFT sensor, the camera also takes stunningly detailed 16MP images, while the integrated 3-axis gimbal keeps it level. The X5R was created to meet the needs of even the most demanding film makers and mounts on both the Inspire 1 and the M600 for flight times of 15 minutes and 35 minutes respectively. It can also be transformed into a powerful, stabilized and handheld 4K RAW camera using the DJI Osmo, opening up a suite of accessories from mics to lights to create a camera ideal for everything from indie film making to advertising.
The DJI Zenmuse X5R is the world’s first 4K RAW Micro Four Thirds camera designed for aerial filmmaking. Its Micro Four Thirds sensor captures extreme detail within 12.8 stops of dynamic range. It records video in two ways simultaneously, one in 1.7Gbps-2.4Gbps bitrate for 12 bit 4K Lossless video, the other in 60Mbps bitrate for H.264 to be used as a proxy.
Equipped with the standard Micro Four Thirds mount, the Zenmuse X5R is compatible with different cameras with focal lengths ranging from 24mm to 90mm. Camera aperture, shutter speed, focus and ISO can be remotely controlled via DJI GO app. It is also compatible with DJI Focus for long range focus control, adding more options for filmmakers.
Adobe’s CinemaDNG format is supported, allowing footage to be exported from DJI CineLight into CinemaDNG for further editing in advanced video processing software including DaVinci Resolve, Adobe Premiere CC and more. Videos can also be transcoded into ProRes, making them easy to edit in Apple Final Cut Pro and other video editing software. The ProRes encoder provided by DJI Cinelight has been tested and certified by Apple.
See the power of RAW in this demo:
2016-4-26
buzzcbr
Flight distance : 316545 ft
what software do you use to colour grade lease?
2016-4-26
Alan Guan
Banned
2016-4-26
Alan Guan
Banned
2016-4-26
Morrisson
Flight distance : 20710033 ft
What is the work flow for PC-based editing systems?
2016-4-26
GaijinGeoff
Flight distance : 694334 ft
Isle of Man
It's a truly stunning camera. I love mine.
The only thing I'd ask for is greater PC support, to make the DNG RAW files Premiere compatible on Windows, without the need to use DaVinci Resolve or SlimRAW. Cinelight not so much, just AdobeDNG on Win. But again, epic camera worth the wait.
2016-4-26
kvamens
Norway
So the editing prossess is much depending on a Apple setup for best quality, what about PC platform?
2016-4-27
stuartdye_photo
WOOOW that looks great!!! If you have a spare one DJi i will give it a Good test for you
2016-5-18
stuartdye_photo
Morrisson Posted at 2016-4-26 20:03
hi, i used to edit Magic lantern RAW footage from my old Canon50D, there is some free ware software made for Windows for RAW to Cineform and its pretty quick. i also downloaded some Red RAW files from the RED Dragon camera in 4k and 6k and my sony vaio fit i5 could handle the RAW 4k in premiere CC with the free RED add-on software. with raw there is NO decompressing and recompressing...it is just displaying Frames of video. Davinci resolve is what i used to use just to batch convert from RAW to high bit rate H264 or Cineform.mov.
hope this helps.
2016-5-18
Morrisson
stuartdye_photo Posted at 2016-5-18 20:13
hi, i used to edit Magic lantern RAW footage from my old Canon50D, there is some free ware softwar ...
Hmmm...interesting.
Ok! That sounds not so bad.
2016-5-23
WYHSniper1007
Flight distance : 1003822 ft
How do you color grade this?
2017-1-4
