phantom 3 pro white spots in video and lines in bright areas
2644 16 2016-4-30
soingham
Hi all,
I am having an issue lately with my P3P, it has white spots in the video feed and in recorded video as well as lines in all bright areas of video.
I have made sure that over exposure mode  is turned off, i have changed channels on video.
This all started after the update to 1.8.8 or whatever it is and i have since back dated to older versions and this issue is still hapening.
I am also geting an IMU warning every now and then and it will not alow the motors to start.
I have since reloaded the version  1.7 update and this is still hapening.
Please help as i run an aerial video business and this is ruining all of my shots.
2016-4-30
DJI-Paladin
Flight distance : 2408 ft
Hello soingham, could you post some screenshot of this issue here? Besides, did the drone crash before?
2016-4-30
soingham
DJI-Paladin Posted at 2016-4-30 17:41
Hello soingham, could you post some screenshot of this issue here? Besides, did the drone crash befo ...
Thanks for the reply,
No the drone has never crashed or had a hard landing, i am very carefull when landing.
I will attach a screen shot shortly of the image quality.
Regards
Shaun.
2016-4-30
soingham
Please see video link below regarding the White spots in lowlights and lines in highlights
http://youtu.be/7Pxgmhlx-PQ
2016-5-1
soingham
Please see the link below regarding the White spots in the lowlights and lines in highlights
2016-5-1
soingham
2016-5-1
DJI-Paladin
China
soingham@gmail. Posted at 2016-5-1 23:11
http: ...
It is a hardware issue. I'd suggest you to contact our online support via http://www.dji.com/support/product or send an email to support@dji.com for the repairing request.Thank you.
2016-5-2
soingham
Thank you, so it is still under warranty, will this be a warraty claim?
2016-5-5
soingham
just tried to use the online support...... got a computer response and then nothing.
would not recomend
now to try the email support
2016-5-5
l1dobbuku
Zambia
Hi Soingham,
Im having the exact same problem and it just randomly started about 7 days ago. See attached screen shots of my video footage. Screen shots of phantom 3 pro footage
Have you had any luck resolving your problem?
2016-5-9
Shaun_au
l1dobbuku Posted at 2016-5-10 01:36
Hi Soingham,
Im having the exact same problem and it just randomly started about 7 days ago. See at ...
Hi there,
Yes i have had some success with DJI's email technical service support, Justin from DJI has been looking after my case and my P3P is due to be collected tomorrow and shipped off to the Australian DJI repair center.
I have been told the issue is a hardware issue and need to be examined and repaired, i am unsure what the issue is exactly but DJI are willing to investigate, repair and freight all at their cost if it is a DJI component failure, otherwise i will have to pay for the repairs. I have never had a hard landing and definitely never crashed it so i cant see how it is a user fault as these same issues are popping up around the globe with the same faults symptoms.
I suggest you email DJI support ASAP and get the process started on the repair, otherwise try taking it back to the store where you purchased the phantom and ask for an exchange as depending on where you live in the world the store must refund, repair or replace the faulty item (check your local consumer laws first)
I hope this helps.
2016-5-11
Shaun_au
Hi Soingham,
Your footage and pics are producing the same error as my P3P did
Definitely get onto DJI support asap
2016-5-11
DJI-Jamie
Flight distance : 112405 ft
soingham@gmail. Posted at 2016-5-6 12:21
would not reco ...
Hi soingham,
Were you able to get in touch with Email Support for assistance?
2016-5-12
Shaun_au
Yes got in touch with DJI support and they have been very helpful and have since repaired the P3P and will be sending it back to me on Monday
the report said something about the camera lens needing to be replace, not sure how this causes lines and spots that move depending on light sensitivity but that was the reason and parts issued so maybe it was a camera replacement?
2016-5-20
DJI-Jamie
Shaun_au Posted at 2016-5-20 22:07
Yes got in touch with DJI support and they have been very helpful and have since repaired the P3P  ...
Good to hear you'll be up and running soon.
If there was a quality issue with the lens, the imperfections could have affected the camera's sensors and how it processes light/ information. Without seeing the service record, it would be hard to confirm if it was just the lens or if they did replace the camera completely. Either way, you should be good to go.
2016-5-20
Shaun_au
DJI-Jamie Posted at 2016-5-20 23:14
If there was a quality issue with the lens, ...
Thanks DJI-Jamie,
The P3P is all fixed now and i have racked up 8 or more full flights since and the clear 4K clarity is back as it should be. it does apear to have had the whole camera replaced but either way i am happy and the repair team took care of my P3P and turned it around in a short time frame
2016-6-2
DJI-Jamie
Shaun_au Posted at 2016-6-2 22:40
Thanks DJI-Jamie,
The P3P is all fixed now and i have racked up 8 or more full flights since and t ...
That's great news. I hope to see some of that footage on SkyPixel .
Happy flying!
2016-6-2
