Donnie
Flight distance : 3636782 ft
I dont think it wise to place a screw there, it will invite stress cracks, I think as flightime 1 stated, get some fresh two way tape an re -install.
One trick on two- way tape is to wipe the areas to be taped with alcohol wipes and also be sure to wipe your fingers tips as well, any oil is then removed and you will find the bond between surfaces is much greater, do not touch the two- way tape on the sticky side, use a x-acto blade or razor, you will be amazed how much better the bond is this way.
Both sides that are getting the two-way tape need to be wiped down thoroughly with alcohol wipes .
Or maybe instead of two way tape, use some GOOP, it has a nice bond but can still be removed if need be , just blace a dab on the bottom of the floor of the riser, this would make a nice clean install.
donnie
