RichJ53
Flight distance : 1837356 ft
I have seen this when the remote is out of calibration (for some reason) ...go into the Go App and hit the remote icon, then select controller Calibration follow the steps.
If this doesn't work try the following ideas too.
Try resetting the RC by using the following button combination:
* Turn on the controller, and the aircraft should be off.
* Press C1, C2, and shutter on the controller then turn the controller off.
* Turn on both the aircraft and the controller
Manually relink the aircraft to the RC using the following:
* Turn on both the aircraft and the controller.
* Press C1, C2, and the record button on the controller, then the controller will beep like D-DD.
*Let go all fingers, press the wheel on the right side of the controller and then the first light of the controller will become blue and it will constantly beep DDDD.
* Use a pen to click the linking button on the aircraft and hold for 3-5 seconds, and then take the pen off the aircraft and wait, it will be linked soon.
Rich
