david.askew
Hi All,
Can anyone answer me a couple of questions regarding the app please?
As I understand it, the "Unlock Motors" feature is supposed to unlock the motors so you can start them using the controller rather than using the auto-takeoff which doesn't need the motors to be unlocked for (can someone confirm this?).
If the above is true how do you actually lock the motors in the first place? Is this done by entering it into travel mode?
Also, with regards to the map feature you can draw lines with your fingers, I understand this is simply to draw marks on the map you may want the drone to take it's flight path. Kinda like a tracer so it's easy for you to follow a set route? Or is there another reason for it?
Thanks in advance.
