Hello!
After the upgrade, did you connect your mobile device to the Internet before connecting to the Osmo WiFi?
Please go through the Osmo Pro release note again for any possible help: https://dl.djicdn.com/downloads/ ... _Note_en_160421.pdf
I have the exact same issue. Yes DJI GO has been connected to the Internet... the OSMO setup is SO buggy I cant believe I spent so much money to be a guinea pig!
here's my log:
========== 2014.01.01 00:00:08 remo-con disconnect======
Packet: OSMO_FC550_FW_V01.01.00.11.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the device.
Result: Abort.
========== 2014.01.01 00:00:07 remo-con disconnect======
Result: Abort.
========== 2014.01.01 00:00:09 remo-con disconnect======
Packet: OSMO_FC550_FW_V01.01.00.10.bin
Result: Abort.
The current firmware does not support downgrade. Use a different version of firmware to downgrade the target version.
Result: Abort.
wslam Posted at 2016-5-12 02:14
I have the exact same issue. Yes DJI GO has been connected to the Internet... the OSMO setup is SO b ...
Hello!
Our engineers will help to figure out the problem, please don't worry!
Before any solution, could you please tell me when and where you bought your Osmo? What the SN of your Osmo, please?
Hello, again!
To fix the firmware issue of your Osmo, our engineers have provided another firmware bin file for you.
Please download the bin file in the Dropbox link and upgrade your firmware again. https://www.dropbox.com/s/ij81xg ... 1.01.00.20.bin?dl=0
If there's any other problem, please feel free to contact us!
Thanks!
Hi paull,
This issue is just an exception, I'm sure that only quite a few people may encounter this issue.
The new bin firmware file is directly provided by our engineers in HQ specifically for the issue, so our EU Support may be not very clear about the details.
Last login: Thu Jun 29 07:36:59 on ttys000
davids-mbp:~ DavidsMac$ /Volumes/Untitled/MISC/LOG/OSMO_FC550_CAM_VERSION ; exit;
/Volumes/Untitled/MISC/LOG/OSMO_FC550_CAM_VERSION: line 1: ?: command not found
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
DJI-Adela Posted at 2016-5-12 00:37
Hello, again!
What am I supposed to do with this bin file? I just download it to my phone and upgrade again? I'm having the same audio issue everyone else is having with osmo pro where i can hear the audio through my app but no where else.
dmakproductions Posted at 2017-7-6 12:58
Have you opened the button ''Audio Record'' on Camera Settings---Audio Control? Is microphone red when you take video?
Hello, again!
do you have a downloadable copy for the above firmware.....
