joakim
Flight distance : 149078 ft
Sweden
It didn't do anything and the logs tells that is the same version.
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3X_FW_V01.08.0080.bin
Upgrading ...
Result: Success.
Packet: P3X_FW_V01.07.0060.bin
Upgrading ...
Result: Success.
========== 2016.05.15 10:43:25 =====================
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
Upgrading ...
Result: Success.
Result: Abort.
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
========== 2016.05.15 15:14:18 =====================
Result: Abort.
Result: Abort.
========== 2016.05.15 16:54:19 =====================
Result: Abort.
========== 2014.01.01 00:00:42 remo-con disconnect======
Result: Abort.
========== 2016.05.15 19:01:38 =====================
Result: Abort.
========== 2016.05.15 19:21:13 =====================
Result: Abort.
========== 2016.05.15 19:24:16 =====================
Result: Abort.
========== 2016.05.15 19:35:59 =====================
Result: Abort.
========== 2016.05.15 20:10:05 =====================
Result: Abort.
========== 2016.05.15 22:10:29 =====================
Result: Abort.
========== 2016.05.15 22:47:50 =====================
Result: Abort.
========== 2016.05.15 22:56:19 =====================
Result: Abort.
========== 2016.05.15 23:17:13 =====================
Result: Abort.
========== 2014.01.01 00:00:40 remo-con disconnect======
Result: Abort.
========== 2016.05.16 07:31:35 =====================
Result: Abort.
========== 2016.05.16 07:35:18 =====================
Result: Abort.
========== 2016.05.16 16:38:49 =====================
Result: Abort.
========== 2016.05.16 17:35:45 =====================
Result: Abort.
========== 2016.05.16 17:48:36 =====================
Result: Abort.
========== 2014.01.01 00:06:19 remo-con disconnect======
Result: Abort.
========== 2014.01.01 00:00:14 remo-con disconnect======
Result: Abort.
========== 2016.05.16 19:32:48 =====================
Result: Abort.
Result: Abort.
[00016799]========== remo-con disconnect. boot(15) ============
[00016935]Firmware [C:\PDM368Fw3.bin] detected, card sn [0x50ce016d].
[00016972][08 00] Firmware upgrade start...
[00523950][08 00] Firmware upgrade finished successfully.
[00523995]Done.
[00013107]========== remo-con disconnect. boot(15) ============
[00013146]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x2857532b].
[00013183]Packet upgrade start...
[00013227]Packet checking...
[00013266]Packet vlink 01.08.0080 <-> 01.07.0060.
[00013336]Done.
[00013372]Version checking[1]...
[00013458][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013538][03 06][00] v2.4.0.4 -> v2.4.14.5 need upgrade.
[00013586][04 00][00] v1.41.0.0 -> v1.44.0.0 need upgrade.
[00013698][11 00][00] v1.7.0.0 -> v1.7.15.1 need upgrade.
[00013818][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013901][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013991][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014071][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014204][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014306][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014447][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014496][19 00][00] v255.255.255.254 -> v1.0.8.96
[00014535][01 00][00] v1.25.4236 -> v1.30.5036 need upgrade
[00014577][01 01][00] v1.25.4236 -> v1.30.5036 need upgrade
[00014629][08 00][00] v0.13.0.7 -> v0.13.0.7
[00014677][09 00][00] v2.13.0.0 -> v3.0.0.10 need upgrade.
[00014713]Done.
[00016754]Waiting for user confirm...
[00026789]Timeout, start upgrade automatically.
[00026863]Firmware upgrading[1]...
[00038360][01 00] Firmware upgrade start...
[00012248][01 00] Firmware upgrade finished successfully.
[00012299]Done.
[00012335]Packet [C:\P3X_FW_V01.08.0080.bin] resumed, card sn [0x2857532b].
[00012376]Packet vlink 01.08.0080 <-> 01.07.0060.
[00012450]Version checking[2]...
[00012533][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012612][03 06][00] v2.4.0.4 -> v2.4.14.5 need upgrade.
[00012662][04 00][00] v1.41.0.0 -> v1.44.0.0 need upgrade.
[00012774][11 00][00] v1.7.0.0 -> v1.7.15.1 need upgrade.
[00012986][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013086][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013162][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013254][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013391][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013501][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013615][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013672][19 00][00] v255.255.255.254 -> v1.0.8.96
[00013711][01 00][05] v1.30.5036 -> v1.30.5036
[00013755][01 01][00] v1.25.4236 -> v1.30.5036 need upgrade
[00013810][08 00][00] v0.13.0.7 -> v0.13.0.7
[00013872][09 00][00] v2.13.0.0 -> v3.0.0.10 need upgrade.
[00013916]Done.
[00013954]Firmware upgrading[2]...
[00014094][01 01] Firmware upgrade start...
[00044396][01 01] Firmware upgrade finished successfully.
[00044452][11 00] Firmware upgrade start...
[00092113][11 00] Firmware upgrade finished successfully.
[00092357][03 06] Firmware upgrade start...
[00394036][03 06] Firmware upgrade finished successfully.
[00394097][09 00] Firmware upgrade start...
[00446159][09 00] Firmware upgrade finished successfully.
[00446233][04 00] Firmware upgrade start...
[00504981][04 00] Firmware upgrade finished successfully.
[00505023]Done.
[00505070]Version checking[3]...
[00505139][03 05][00] v34.2.0.9 -> v34.2.0.9
[00505201][03 06][05] v2.4.14.5 -> v2.4.14.5
[00505280][04 00][05] v1.44.0.0 -> v1.44.0.0
[00505380][11 00][05] v1.7.15.1 -> v1.7.15.1
[00505473][12 00][00] v1.10.0.0 -> v1.10.0.0
[00505548][12 01][00] v1.10.0.0 -> v1.10.0.0
[00505634][12 02][00] v1.10.0.0 -> v1.10.0.0
[00505709][12 03][00] v1.10.0.0 -> v1.10.0.0
[00505859][15 00][00] v1.1.2.0 -> v1.1.2.0
[00505943][17 00][00] v1.1.1.7 -> v1.1.1.7
[00506062][17 01][00] v1.0.2.7 -> v1.0.2.7
[00506127][19 00][00] v255.255.255.254 -> v1.0.8.96
[00506167][01 00][05] v1.30.5036 -> v1.30.5036
[00506204][01 01][05] v1.30.5036 -> v1.30.5036
[00506289][08 00][00] v0.13.0.7 -> v0.13.0.7
[00506347][09 00][05] v3.0.0.10 -> v3.0.0.10
[00506384]Packet upgrade finish successfully.
[00013658]========== remo-con disconnect. boot(15) ============
[00013697]Packet [C:\P3X_FW_V01.07.0060.bin] detected, card sn [0x2857532b].
[00013735]Packet upgrade start...
[00013784]Packet checking...
[00013826]Packet vlink 01.07.0060 <-> 01.06.0040.
[00013866]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 1).
[00013905]Done.
[00013951]Version checking[1]...
[00014034][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014119][03 06][00] v2.4.14.5 -> v2.4.13.0
[00014168][04 00][00] v1.44.0.0 -> v1.41.0.0
[00014280][11 00][00] v1.7.15.1 -> v1.7.15.1
[00014399][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014507][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014600][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014685][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014834][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014924][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015052][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015119][19 00][00] v255.255.255.254 -> v1.0.8.96
[00015159][01 00][00] v1.30.5036 -> v1.29.4920 need upgrade
[00015201][01 01][00] v1.30.5036 -> v1.29.4920 need upgrade
[00015271][08 00][00] v0.13.0.7 -> v0.13.0.7
[00015338][09 00][00] v3.0.0.10 -> v2.13.0.0
[00015379]Done.
[00017427]Waiting for user confirm...
[00027469]Timeout, start upgrade automatically.
[00027547]Firmware upgrading[1]...
[00027684][01 01] Firmware upgrade start...
[00057976][01 01] Firmware upgrade finished successfully.
[00058018]Done.
[00058061]Version checking[2]...
[00058136][03 05][00] v34.2.0.9 -> v34.2.0.9
[00058223][03 06][00] v2.4.14.5 -> v2.4.13.0
[00058276][04 00][00] v1.44.0.0 -> v1.41.0.0 need upgrade.
[00058402][11 00][00] v1.7.15.1 -> v1.7.15.1
[00058506][12 00][00] v1.10.0.0 -> v1.10.0.0
[00058603][12 01][00] v1.10.0.0 -> v1.10.0.0
[00058711][12 02][00] v1.10.0.0 -> v1.10.0.0
[00058810][12 03][00] v1.10.0.0 -> v1.10.0.0
[00058967][15 00][00] v1.1.2.0 -> v1.1.2.0
[00059045][17 00][00] v1.1.1.7 -> v1.1.1.7
[00059165][17 01][00] v1.0.2.7 -> v1.0.2.7
[00059221][19 00][00] v255.255.255.254 -> v1.0.8.96
[00059369][01 00][00] v1.30.5036 -> v1.29.4920 need upgrade
[00059410][01 01][05] v1.29.4920 -> v1.29.4920
[00059468][08 00][00] v0.13.0.7 -> v0.13.0.7
[00059522][09 00][00] v3.0.0.10 -> v2.13.0.0
[00059563]Done.
[00059603]Firmware upgrading[2]...
[00059675][04 00] Firmware upgrade start...
[00118259][04 00] Firmware upgrade finished successfully.
[00118302]Done.
[00118341]Version checking[3]...
[00118425][03 05][00] v34.2.0.9 -> v34.2.0.9
[00118505][03 06][00] v2.4.14.5 -> v2.4.13.0
[00118565][04 00][05] v1.41.0.0 -> v1.41.0.0
[00118685][11 00][00] v1.7.15.1 -> v1.7.15.1
[00118789][12 00][00] v1.10.0.0 -> v1.10.0.0
[00118893][12 01][00] v1.10.0.0 -> v1.10.0.0
[00118973][12 02][00] v1.10.0.0 -> v1.10.0.0
[00119049][12 03][00] v1.10.0.0 -> v1.10.0.0
[00119196][15 00][00] v1.1.2.0 -> v1.1.2.0
[00119310][17 00][00] v1.1.1.7 -> v1.1.1.7
[00119430][17 01][00] v1.0.2.7 -> v1.0.2.7
[00119485][19 00][00] v255.255.255.254 -> v1.0.8.96
[00119534][01 00][00] v1.30.5036 -> v1.29.4920 need upgrade
[00119573][01 01][05] v1.29.4920 -> v1.29.4920
[00119626][08 00][00] v0.13.0.7 -> v0.13.0.7
[00119685][09 00][00] v3.0.0.10 -> v2.13.0.0
[00119730]Done.
[00119770]Firmware upgrading[3]...
[00131127][01 00] Firmware upgrade start...
[00012135][01 00] Firmware upgrade finished successfully.
[00012179]Done.
[00012220]Packet [C:\P3X_FW_V01.07.0060.bin] resumed, card sn [0x2857532b].
[00012267]Packet vlink 01.07.0060 <-> 01.06.0040.
[00012319]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 1).
[00012360]Version checking[2]...
[00012435][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012515][03 06][00] v2.4.14.5 -> v2.4.13.0
[00012569][04 00][05] v1.41.0.0 -> v1.41.0.0
[00012697][11 00][00] v1.7.15.1 -> v1.7.15.1
[00012784][12 00][00] v1.10.0.0 -> v1.10.0.0
[00012883][12 01][00] v1.10.0.0 -> v1.10.0.0
[00012983][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013064][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013212][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013424][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013559][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013614][19 00][00] v255.255.255.254 -> v1.0.8.96
[00013660][01 00][05] v1.29.4920 -> v1.29.4920
[00013701][01 01][05] v1.29.4920 -> v1.29.4920
[00013766][08 00][00] v0.13.0.7 -> v0.13.0.7
[00013834][09 00][00] v3.0.0.10 -> v2.13.0.0
[00013875]Packet upgrade finish successfully.
[00013499]========== 2016.05.15 10:43:27. boot(15) ============
[00013543]Packet [C:\P3X_FW_V01.07.0060.bin] detected, card sn [0x2857532b].
[00013588]Packet upgrade start...
[00013634]Packet checking...
[00013681]Packet vlink 01.07.0060 <-> 01.06.0040.
[00013727]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 1).
[00013780]Done.
[00013823]Version checking[1]...
[00013913][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014011][03 06][00] v2.4.14.5 -> v2.4.13.0
[00014060][04 00][00] v1.41.0.0 -> v1.41.0.0
[00014177][11 00][00] v1.7.15.1 -> v1.7.15.1
[00014265][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014365][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014465][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014565][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014719][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014821][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014961][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015032][19 00][00] v255.255.255.254 -> v1.0.8.96
[00015074][01 00][00] v1.29.4920 -> v1.29.4920
[00015116][01 01][00] v1.29.4920 -> v1.29.4920
[00015194][08 00][00] v0.13.0.7 -> v0.13.0.7
[00015251][09 00][00] v3.0.0.10 -> v2.13.0.0
[00015297]Packet upgrade cancelled at version checking.
[00013968]========== remo-con disconnect. boot(15) ============
[00014010]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x2857532b].
[00014056]Packet upgrade start...
[00014105]Packet checking...
[00014150]Packet vlink 01.08.0080 <-> 01.07.0060.
[00014191]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00014231]Done.
[00014283]Version checking[1]...
[00014375][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014575][03 06][00] v2.4.14.5 -> v2.4.14.5
[00014639][04 00][00] v1.41.0.0 -> v1.44.0.0 need upgrade.
[00014756][11 00][00] v1.7.15.1 -> v1.7.15.1
[00014845][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014936][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015045][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015151][12 03][00] v1.10.0.0 -> v1.10.0.0
[00015304][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015404][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015550][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015610][19 00][00] v255.255.255.254 -> v1.0.8.96
[00015660][01 00][00] v1.29.4920 -> v1.30.5036 need upgrade
[00015701][01 01][00] v1.29.4920 -> v1.30.5036 need upgrade
[00015761][08 00][00] v0.13.0.7 -> v0.13.0.7
[00015829][09 00][00] v3.0.0.10 -> v3.0.0.10
[00015874]Done.
[00017923]Waiting for user confirm...
[00027967]Timeout, start upgrade automatically.
[00028055]Firmware upgrading[1]...
[00039392][01 00] Firmware upgrade start...
[00012131][01 00] Firmware upgrade finished successfully.
[00012189]Done.
[00012249]Packet [C:\P3X_FW_V01.08.0080.bin] resumed, card sn [0x2857532b].
[00012296]Packet vlink 01.08.0080 <-> 01.07.0060.
[00012347]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00012388]Version checking[2]...
[00012476][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012556][03 06][00] v2.4.14.5 -> v2.4.14.5
[00012605][04 00][00] v1.41.0.0 -> v1.44.0.0 need upgrade.
[00012716][11 00][00] v1.7.15.1 -> v1.7.15.1
[00012836][12 00][00] v1.10.0.0 -> v1.10.0.0
[00012911][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013016][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013090][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013246][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013326][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013446][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013511][19 00][00] v255.255.255.254 -> v1.0.8.96
[00013555][01 00][05] v1.30.5036 -> v1.30.5036
[00013599][01 01][00] v1.29.4920 -> v1.30.5036 need upgrade
[00013655][08 00][00] v0.13.0.7 -> v0.13.0.7
[00013711][09 00][00] v3.0.0.10 -> v3.0.0.10
[00013756]Done.
[00013923]Firmware upgrading[2]...
[00014082][01 01] Firmware upgrade start...
[00044401][01 01] Firmware upgrade finished successfully.
[00044477][04 00] Firmware upgrade start...
[00103306][04 00] Firmware upgrade finished successfully.
[00103354]Done.
[00103399]Version checking[3]...
[00103482][03 05][00] v34.2.0.9 -> v34.2.0.9
[00103563][03 06][00] v2.4.14.5 -> v2.4.14.5
[00103618][04 00][05] v1.44.0.0 -> v1.44.0.0
[00103743][11 00][00] v1.7.15.1 -> v1.7.15.1
[00103837][12 00][00] v1.10.0.0 -> v1.10.0.0
[00103937][12 01][00] v1.10.0.0 -> v1.10.0.0
[00104038][12 02][00] v1.10.0.0 -> v1.10.0.0
[00104112][12 03][00] v1.10.0.0 -> v1.10.0.0
[00104288][15 00][00] v1.1.2.0 -> v1.1.2.0
[00104394][17 00][00] v1.1.1.7 -> v1.1.1.7
[00104512][17 01][00] v1.0.2.7 -> v1.0.2.7
[00104577][19 00][00] v255.255.255.254 -> v1.0.8.96
[00104640][01 00][05] v1.30.5036 -> v1.30.5036
[00104685][01 01][05] v1.30.5036 -> v1.30.5036
[00104745][08 00][00] v0.13.0.7 -> v0.13.0.7
[00104816][09 00][00] v3.0.0.10 -> v3.0.0.10
[00104864]Packet upgrade finish successfully.
[00013552]========== remo-con disconnect. boot(15) ============
[00013602]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x2857532b].
[00013649]Packet upgrade start...
[00013697]Packet checking...
[00013744]Packet vlink 01.08.0080 <-> 01.07.0060.
[00013793]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00013837]Done.
[00013883]Version checking[1]...
[00013972][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014071][03 06][00] v2.4.14.5 -> v2.4.14.5
[00014130][04 00][00] v1.44.0.0 -> v1.44.0.0
[00014255][11 00][00] v1.7.15.1 -> v1.7.15.1
[00014352][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014435][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014533][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014632][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014767][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014844][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014962][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015020][19 00][00] v255.255.255.254 -> v1.0.8.96
[00015173][01 00][00] v1.30.5036 -> v1.30.5036
[00015224][01 01][00] v1.30.5036 -> v1.30.5036
[00015289][08 00][00] v0.13.0.7 -> v0.13.0.7
[00015361][09 00][00] v3.0.0.10 -> v3.0.0.10
[00015404]Packet upgrade cancelled at version checking.
[00013613]========== remo-con disconnect. boot(15) ============
[00013660]Packet [C:\P3X_FW_V01.07.0060.bin] detected, card sn [0x2857532b].
[00013706]Packet upgrade start...
[00013761]Packet checking...
[00013808]Packet vlink 01.07.0060 <-> 01.06.0040.
[00013860]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 1).
[00013906]Done.
[00013959]Version checking[1]...
[00014114][03 06][00] v2.4.14.5 -> v2.4.13.0
[00014166][04 00][00] v1.44.0.0 -> v1.41.0.0
[00014292][11 00][00] v1.7.15.1 -> v1.7.15.1
[00014381][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014481][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014585][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014681][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014829][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014919][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015037][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015116][19 00][00] v255.255.255.254 -> v1.0.8.96
[00015162][01 00][00] v1.30.5036 -> v1.29.4920 need upgrade
[00015208][01 01][00] v1.30.5036 -> v1.29.4920 need upgrade
[00015296][08 00][00] v0.13.0.7 -> v0.13.0.7
[00015356][09 00][00] v3.0.0.10 -> v2.13.0.0
[00015401]Done.
[00017456]Waiting for user confirm...
[00027502]Timeout, start upgrade automatically.
[00027606]Firmware upgrading[1]...
[00027748][01 01] Firmware upgrade start...
[00058051][01 01] Firmware upgrade finished successfully.
[00058099]Done.
[00058149]Version checking[2]...
[00058235][03 05][00] v34.2.0.9 -> v34.2.0.9
[00058315][03 06][00] v2.4.14.5 -> v2.4.13.0
[00058370][04 00][00] v1.44.0.0 -> v1.41.0.0
[00058495][11 00][00] v1.7.15.1 -> v1.7.15.1
[00058584][12 00][00] v1.10.0.0 -> v1.10.0.0
[00058684][12 01][00] v1.10.0.0 -> v1.10.0.0
[00058784][12 02][00] v1.10.0.0 -> v1.10.0.0
[00059005][12 03][00] v1.10.0.0 -> v1.10.0.0
[00059161][15 00][00] v1.1.2.0 -> v1.1.2.0
[00059243][17 00][00] v1.1.1.7 -> v1.1.1.7
[00059385][17 01][00] v1.0.2.7 -> v1.0.2.7
[00059464][19 00][00] v255.255.255.254 -> v1.0.8.96
[00059511][01 00][00] v1.30.5036 -> v1.29.4920 need upgrade
[00059562][01 01][05] v1.29.4920 -> v1.29.4920
[00059632][08 00][00] v0.13.0.7 -> v0.13.0.7
[00059698][09 00][00] v3.0.0.10 -> v2.13.0.0
[00059746]Done.
[00059800]Firmware upgrading[2]...
[00071826][01 00] Firmware upgrade start...
[00012129][01 00] Firmware upgrade finished successfully.
[00012187]Done.
[00012236]Packet [C:\P3X_FW_V01.07.0060.bin] resumed, card sn [0x2857532b].
[00012286]Packet vlink 01.07.0060 <-> 01.06.0040.
[00012344]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 1).
[00012478][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012557][03 06][00] v2.4.14.5 -> v2.4.13.0
[00012613][04 00][00] v1.44.0.0 -> v1.41.0.0
[00012738][11 00][00] v1.7.15.1 -> v1.7.15.1
[00012837][12 00][00] v1.10.0.0 -> v1.10.0.0
[00012937][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013037][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013125][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013274][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013386][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013525][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013601][19 00][00] v255.255.255.254 -> v1.0.8.96
[00013654][01 00][05] v1.29.4920 -> v1.29.4920
[00013702][01 01][05] v1.29.4920 -> v1.29.4920
[00013769][08 00][00] v0.13.0.7 -> v0.13.0.7
[00013840][09 00][00] v3.0.0.10 -> v2.13.0.0
[00013887]Packet upgrade finish successfully.
[00013484]========== remo-con disconnect. boot(15) ============
[00013531]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x2857532b].
[00013577]Packet upgrade start...
[00013633]Packet checking...
[00013682]Packet vlink 01.08.0080 <-> 01.07.0060.
[00013730]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00013782]Done.
[00013935]Version checking[1]...
[00014013][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014113][03 06][00] v2.4.14.5 -> v2.4.14.5
[00014170][04 00][00] v1.44.0.0 -> v1.44.0.0
[00014293][11 00][00] v1.7.15.1 -> v1.7.15.1
[00014407][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014607][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014707][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014871][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014962][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015102][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015178][19 00][00] v255.255.255.254 -> v1.0.8.96
[00015228][01 00][00] v1.29.4920 -> v1.30.5036 need upgrade
[00015284][01 01][00] v1.29.4920 -> v1.30.5036 need upgrade
[00015352][08 00][00] v0.13.0.7 -> v0.13.0.7
[00015422][09 00][00] v3.0.0.10 -> v3.0.0.10
[00015472]Done.
[00017523]Waiting for user confirm...
[00027572]Timeout, start upgrade automatically.
[00027676]Firmware upgrading[1]...
[00039713][01 00] Firmware upgrade start...
[00012139][01 00] Firmware upgrade finished successfully.
[00012190]Done.
[00012240]Packet [C:\P3X_FW_V01.08.0080.bin] resumed, card sn [0x2857532b].
[00012292]Packet vlink 01.08.0080 <-> 01.07.0060.
[00012350]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00012398]Version checking[2]...
[00012496][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012595][03 06][00] v2.4.14.5 -> v2.4.14.5
[00012655][04 00][00] v1.44.0.0 -> v1.44.0.0
[00012776][11 00][00] v1.7.15.1 -> v1.7.15.1
[00012884][12 00][00] v1.10.0.0 -> v1.10.0.0
[00012983][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013083][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013215][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013352][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013445][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013580][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013655][19 00][00] v255.255.255.254 -> v1.0.8.96
[00013703][01 00][05] v1.30.5036 -> v1.30.5036
[00013753][01 01][00] v1.29.4920 -> v1.30.5036 need upgrade
[00013820][08 00][00] v0.13.0.7 -> v0.13.0.7
[00014016][09 00][00] v3.0.0.10 -> v3.0.0.10
[00014067]Done.
[00014121]Firmware upgrading[2]...
[00014287][01 01] Firmware upgrade start...
[00044613][01 01] Firmware upgrade finished successfully.
[00044673]Done.
[00044723]Version checking[3]...
[00044817][03 05][00] v34.2.0.9 -> v34.2.0.9
[00044921][03 06][00] v2.4.14.5 -> v2.4.14.5
[00044980][04 00][00] v1.44.0.0 -> v1.44.0.0
[00045118][11 00][00] v1.7.15.1 -> v1.7.15.1
[00045221][12 00][00] v1.10.0.0 -> v1.10.0.0
[00045321][12 01][00] v1.10.0.0 -> v1.10.0.0
[00045426][12 02][00] v1.10.0.0 -> v1.10.0.0
[00045577][12 03][00] v1.10.0.0 -> v1.10.0.0
[00045721][15 00][00] v1.1.2.0 -> v1.1.2.0
[00045821][17 00][00] v1.1.1.7 -> v1.1.1.7
[00045961][17 01][00] v1.0.2.7 -> v1.0.2.7
[00046036][19 00][00] v255.255.255.254 -> v1.0.8.96
[00046087][01 00][05] v1.30.5036 -> v1.30.5036
[00046144][01 01][05] v1.30.5036 -> v1.30.5036
[00046210][08 00][00] v0.13.0.7 -> v0.13.0.7
[00046277][09 00][00] v3.0.0.10 -> v3.0.0.10
[00046331]Packet upgrade finish successfully.
[00013458]========== 2016.05.15 15:14:20. boot(15) ============
[00013509]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x2857532b].
[00013561]Packet upgrade start...
[00013618]Packet checking...
[00013670]Packet vlink 01.08.0080 <-> 01.07.0060.
[00013720]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00013776]Done.
[00013827]Version checking[1]...
[00013914][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014014][03 06][00] v2.4.14.5 -> v2.4.14.5
[00014078][04 00][00] v1.44.0.0 -> v1.44.0.0
[00014214][11 00][00] v1.7.15.1 -> v1.7.15.1
[00014343][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014442][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014542][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014644][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014787][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014898][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015107][19 00][00] v255.255.255.254 -> v1.0.8.96
[00015157][01 00][00] v1.30.5036 -> v1.30.5036
[00015314][01 01][00] v1.30.5036 -> v1.30.5036
[00015383][08 00][00] v0.13.0.7 -> v0.13.0.7
[00015468][09 00][00] v3.0.0.10 -> v3.0.0.10
[00015519]Packet upgrade cancelled at version checking.
[00013101]========== remo-con disconnect. boot(15) ============
[00013161]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x2857532b].
[00013214]Packet upgrade start...
[00013270]Packet checking...
[00013331]Packet vlink 01.08.0080 <-> 01.07.0060.
[00013381]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00013437]Done.
[00013494]Version checking[1]...
[00013591][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013691][03 06][00] v2.4.14.5 -> v2.4.14.5
[00013755][04 00][00] v1.44.0.0 -> v1.44.0.0
[00013890][11 00][00] v1.7.15.1 -> v1.7.15.1
[00014010][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014120][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014250][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014359][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014504][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014620][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014760][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014826][19 00][00] v255.255.255.254 -> v1.0.8.96
[00014877][01 00][00] v1.30.5036 -> v1.30.5036
[00014931][01 01][00] v1.30.5036 -> v1.30.5036
[00015006][08 00][00] v0.13.0.7 -> v0.13.0.7
[00015086][09 00][00] v3.0.0.10 -> v3.0.0.10
[00015139]Packet upgrade cancelled at version checking.
[00013052]========== 2016.05.15 16:54:20. boot(15) ============
[00013100]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x2857532b].
[00013154]Packet upgrade start...
[00013206]Packet checking...
[00013258]Packet vlink 01.08.0080 <-> 01.07.0060.
[00013307]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00013357]Done.
[00013404]Version checking[1]...
[00013498][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013598][03 06][00] v2.4.14.5 -> v2.4.14.5
[00013652][04 00][00] v1.44.0.0 -> v1.44.0.0
[00013784][11 00][00] v1.7.15.1 -> v1.7.15.1
[00013887][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014102][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014228][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014329][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014468][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014562][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014713][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014793][19 00][00] v255.255.255.254 -> v1.0.8.96
[00014843][01 00][00] v1.30.5036 -> v1.30.5036
[00014892][01 01][00] v1.30.5036 -> v1.30.5036
[00014965][08 00][00] v0.13.0.7 -> v0.13.0.7
[00015032][09 00][00] v3.0.0.10 -> v3.0.0.10
[00015085]Packet upgrade cancelled at version checking.
[00042517]========== remo-con disconnect. boot(15) ============
[00042572]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x2857532b].
[00042622]Packet upgrade start...
[00042684]Packet checking...
[00042742]Packet vlink 01.08.0080 <-> 01.07.0060.
[00042794]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00042850]Done.
[00042904]Version checking[1]...
[00042982][03 05][00] v34.2.0.9 -> v34.2.0.9
[00043082][03 06][00] v2.4.14.5 -> v2.4.14.5
[00043154][04 00][00] v1.44.0.0 -> v1.44.0.0
[00043282][11 00][00] v1.7.15.1 -> v1.7.15.1
[00043393][12 00][00] v1.10.0.0 -> v1.10.0.0
[00043491][12 01][00] v1.10.0.0 -> v1.10.0.0
[00043591][12 02][00] v1.10.0.0 -> v1.10.0.0
[00043692][12 03][00] v1.10.0.0 -> v1.10.0.0
[00043845][15 00][00] v1.1.2.0 -> v1.1.2.0
[00043946][17 00][00] v1.1.1.7 -> v1.1.1.7
[00044091][17 01][00] v1.0.2.7 -> v1.0.2.7
[00044172][19 00][00] v255.255.255.254 -> v1.0.8.96
[00044226][01 00][00] v1.30.5036 -> v1.30.5036
[00044280][01 01][00] v1.30.5036 -> v1.30.5036
[00044356][08 00][00] v0.13.0.7 -> v0.13.0.7
[00044433][09 00][00] v3.0.0.10 -> v3.0.0.10
[00044485]Packet upgrade cancelled at version checking.
[00013649]========== 2016.05.15 19:01:40. boot(15) ============
[00013705]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x2857532b].
[00013761]Packet upgrade start...
[00013815]Packet checking...
[00013873]Packet vlink 01.08.0080 <-> 01.07.0060.
[00014036]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00014091]Done.
[00014146]Version checking[1]...
[00014237][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014314][03 06][00] v2.4.14.5 -> v2.4.14.5
[00014385][04 00][00] v1.44.0.0 -> v1.44.0.0
[00014512][11 00][00] v1.7.15.1 -> v1.7.15.1
[00014631][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014732][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014820][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014923][12 03][00] v1.10.0.0 -> v1.10.0.0
[00015075][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015180][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015328][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015400][19 00][00] v255.255.255.254 -> v1.0.8.96
[00015457][01 00][00] v1.30.5036 -> v1.30.5036
[00015514][01 01][00] v1.30.5036 -> v1.30.5036
[00015587][08 00][00] v0.13.0.7 -> v0.13.0.7
[00015662][09 00][00] v3.0.0.10 -> v3.0.0.10
[00015713]Packet upgrade cancelled at version checking.
[00013205]========== 2016.05.15 19:21:14. boot(15) ============
[00013264]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x2857532b].
[00013327]Packet upgrade start...
[00013383]Packet checking...
[00013439]Packet vlink 01.08.0080 <-> 01.07.0060.
[00013526]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00013577]Done.
[00013634]Version checking[1]...
[00013731][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013831][03 06][00] v2.4.14.5 -> v2.4.14.5
[00013891][04 00][00] v1.44.0.0 -> v1.44.0.0
[00014011][11 00][00] v1.7.15.1 -> v1.7.15.1
[00014124][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014222][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014328][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014422][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014576][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014675][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014815][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014900][19 00][00] v255.255.255.254 -> v1.0.8.96
[00014959][01 00][00] v1.30.5036 -> v1.30.5036
[00015017][01 01][00] v1.30.5036 -> v1.30.5036
[00015082][08 00][00] v0.13.0.7 -> v0.13.0.7
[00015281][09 00][00] v3.0.0.10 -> v3.0.0.10
[00015346]Packet upgrade cancelled at version checking.
[00013201]========== 2016.05.15 19:24:17. boot(15) ============
[00013261]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x2857532b].
[00013326]Packet upgrade start...
[00013384]Packet checking...
[00013443]Packet vlink 01.08.0080 <-> 01.07.0060.
[00013505]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00013564]Done.
[00013621]Version checking[1]...
[00013732][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013893][04 00][00] v1.44.0.0 -> v1.44.0.0
[00014031][11 00][00] v1.7.15.1 -> v1.7.15.1
[00014159][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014259][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014360][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014460][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014648][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014755][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014900][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014986][19 00][00] v255.255.255.254 -> v1.0.8.96
[00015051][01 00][00] v1.30.5036 -> v1.30.5036
[00015107][01 01][00] v1.30.5036 -> v1.30.5036
[00015200][08 00][00] v0.13.0.7 -> v0.13.0.7
[00015286][09 00][00] v3.0.0.10 -> v3.0.0.10
[00015351]Packet upgrade cancelled at version checking.
[00013214]========== 2016.05.15 19:36:00. boot(15) ============
[00013271]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x2857532b].
[00013335]Packet upgrade start...
[00013398]Packet checking...
[00013461]Packet vlink 01.08.0080 <-> 01.07.0060.
[00013582]Done.
[00013637]Version checking[1]...
[00013730][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013827][03 06][00] v2.4.14.5 -> v2.4.14.5
[00013888][04 00][00] v1.44.0.0 -> v1.44.0.0
[00014026][11 00][00] v1.7.15.1 -> v1.7.15.1
[00014120][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014247][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014347][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014447][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014745][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014855][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015005][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015091][19 00][00] v255.255.255.254 -> v1.0.8.96
[00015155][01 00][00] v1.30.5036 -> v1.30.5036
[00015212][01 01][00] v1.30.5036 -> v1.30.5036
[00015286][08 00][00] v0.13.0.7 -> v0.13.0.7
[00015371][09 00][00] v3.0.0.10 -> v3.0.0.10
[00015430]Packet upgrade cancelled at version checking.
[00013571]========== 2016.05.15 20:10:07. boot(15) ============
[00013630]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x2857532b].
[00013683]Packet upgrade start...
[00013764]Packet checking...
[00013853]Packet vlink 01.08.0080 <-> 01.07.0060.
[00013909]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00013972]Done.
[00014031]Version checking[1]...
[00014125][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014252][03 06][00] v2.4.14.5 -> v2.4.14.5
[00014313][04 00][00] v1.44.0.0 -> v1.44.0.0
[00014465][11 00][00] v1.7.15.1 -> v1.7.15.1
[00014586][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014689][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014825][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014928][12 03][00] v1.10.0.0 -> v1.10.0.0
[00015103][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015234][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015389][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015466][19 00][00] v255.255.255.254 -> v1.0.8.96
[00015525][01 00][00] v1.30.5036 -> v1.30.5036
[00015590][01 01][00] v1.30.5036 -> v1.30.5036
[00015663][08 00][00] v0.13.0.7 -> v0.13.0.7
[00015765][09 00][00] v3.0.0.10 -> v3.0.0.10
[00015824]Packet upgrade cancelled at version checking.
[00013895]========== 2016.05.15 22:10:30. boot(15) ============
[00013953]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x2857532b].
[00014014]Packet upgrade start...
[00014080]Packet checking...
[00014144]Packet vlink 01.08.0080 <-> 01.07.0060.
[00014209]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00014271]Done.
[00014334]Version checking[1]...
[00014555][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014658][03 06][00] v2.4.14.5 -> v2.4.14.5
[00014725][04 00][00] v1.44.0.0 -> v1.44.0.0
[00014858][11 00][00] v1.7.15.1 -> v1.7.15.1
[00014963][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015088][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015198][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015303][12 03][00] v1.10.0.0 -> v1.10.0.0
[00015479][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015599][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015744][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015833][19 00][00] v255.255.255.254 -> v1.0.8.96
[00015893][01 00][00] v1.30.5036 -> v1.30.5036
[00015962][01 01][00] v1.30.5036 -> v1.30.5036
[00016036][08 00][00] v0.13.0.7 -> v0.13.0.7
[00016114][09 00][00] v3.0.0.10 -> v3.0.0.10
[00016179]Packet upgrade cancelled at version checking.
[00013377]========== 2016.05.15 22:47:51. boot(15) ============
[00013443]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x2857532b].
[00013506]Packet upgrade start...
[00013576]Packet checking...
[00013645]Packet vlink 01.08.0080 <-> 01.07.0060.
[00013713]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00013777]Done.
[00013843]Version checking[1]...
[00013939][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014042][03 06][00] v2.4.14.5 -> v2.4.14.5
[00014118][04 00][00] v1.44.0.0 -> v1.44.0.0
[00014263][11 00][00] v1.7.15.1 -> v1.7.15.1
[00014372][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014500][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014608][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014733][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014912][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015023][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015178][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015264][19 00][00] v255.255.255.254 -> v1.0.8.96
[00015322][01 00][00] v1.30.5036 -> v1.30.5036
[00015383][01 01][00] v1.30.5036 -> v1.30.5036
[00015477][08 00][00] v0.13.0.7 -> v0.13.0.7
[00015564][09 00][00] v3.0.0.10 -> v3.0.0.10
[00015624]Packet upgrade cancelled at version checking.
[00013377]========== 2016.05.15 22:56:19. boot(15) ============
[00013524]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x2857532b].
[00013587]Packet upgrade start...
[00013657]Packet checking...
[00013727]Packet vlink 01.08.0080 <-> 01.07.0060.
[00013788]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00013854]Done.
[00013917]Version checking[1]...
[00014014][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014133][03 06][00] v2.4.14.5 -> v2.4.14.5
[00014200][04 00][00] v1.44.0.0 -> v1.44.0.0
[00014351][11 00][00] v1.7.15.1 -> v1.7.15.1
[00014460][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014560][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014660][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014760][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014915][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015037][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015176][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015277][19 00][00] v255.255.255.254 -> v1.0.8.96
[00015342][01 00][00] v1.30.5036 -> v1.30.5036
[00015409][01 01][00] v1.30.5036 -> v1.30.5036
[00015501][08 00][00] v0.13.0.7 -> v0.13.0.7
[00015573][09 00][00] v3.0.0.10 -> v3.0.0.10
[00015637]Packet upgrade cancelled at version checking.
[00013361]========== 2016.05.15 23:17:13. boot(15) ============
[00013422]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x2857532b].
[00013486]Packet upgrade start...
[00013555]Packet checking...
[00013622]Packet vlink 01.08.0080 <-> 01.07.0060.
[00013687]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00013752]Done.
[00013819]Version checking[1]...
[00013929][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014029][03 06][00] v2.4.14.5 -> v2.4.14.5
[00014104][04 00][00] v1.44.0.0 -> v1.44.0.0
[00014249][11 00][00] v1.7.15.1 -> v1.7.15.1
[00014354][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014453][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014560][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014660][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014813][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014912][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015172][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015275][19 00][00] v255.255.255.254 -> v1.0.8.96
[00015345][01 00][00] v1.30.5036 -> v1.30.5036
[00015412][01 01][00] v1.30.5036 -> v1.30.5036
[00015499][08 00][00] v0.13.0.7 -> v0.13.0.7
[00015642]Packet upgrade cancelled at version checking.
[00040892]========== remo-con disconnect. boot(15) ============
[00040955]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x2857532b].
[00041025]Packet upgrade start...
[00041095]Packet checking...
[00041166]Packet vlink 01.08.0080 <-> 01.07.0060.
[00041232]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00041295]Done.
[00041365]Version checking[1]...
[00041484][03 05][00] v34.2.0.9 -> v34.2.0.9
[00041580][03 06][00] v2.4.14.5 -> v2.4.14.5
[00041656][04 00][00] v1.44.0.0 -> v1.44.0.0
[00041801][11 00][00] v1.7.15.1 -> v1.7.15.1
[00041929][12 00][00] v1.10.0.0 -> v1.10.0.0
[00042054][12 01][00] v1.10.0.0 -> v1.10.0.0
[00042168][12 02][00] v1.10.0.0 -> v1.10.0.0
[00042293][12 03][00] v1.10.0.0 -> v1.10.0.0
[00042476][15 00][00] v1.1.2.0 -> v1.1.2.0
[00042589][17 00][00] v1.1.1.7 -> v1.1.1.7
[00042754][17 01][00] v1.0.2.7 -> v1.0.2.7
[00042861][19 00][00] v255.255.255.254 -> v1.0.8.96
[00042924][01 00][00] v1.30.5036 -> v1.30.5036
[00042988][01 01][00] v1.30.5036 -> v1.30.5036
[00043065][08 00][00] v0.13.0.7 -> v0.13.0.7
[00043141][09 00][00] v3.0.0.10 -> v3.0.0.10
[00043205]Packet upgrade cancelled at version checking.
[00014901]========== 2016.05.16 07:31:37. boot(15) ============
[00014968]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x2857532b].
[00015032]Packet upgrade start...
[00015099]Packet checking...
[00015168]Packet vlink 01.08.0080 <-> 01.07.0060.
[00015232]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00015301]Done.
[00015388]Version checking[1]...
[00015500][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015601][03 06][00] v2.4.14.5 -> v2.4.14.5
[00015680][04 00][00] v1.44.0.0 -> v1.44.0.0
[00015940][11 00][00] v1.7.15.1 -> v1.7.15.1
[00016044][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016144][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016249][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016380][12 03][00] v1.10.0.0 -> v1.10.0.0
[00016564][15 00][00] v1.1.2.0 -> v1.1.2.0
[00016683][17 00][00] v1.1.1.7 -> v1.1.1.7
[00016829][17 01][00] v1.0.2.7 -> v1.0.2.7
[00016900][19 00][00] v255.255.255.254 -> v1.0.8.96
[00016969][01 00][00] v1.30.5036 -> v1.30.5036
[00017038][01 01][00] v1.30.5036 -> v1.30.5036
[00017126][08 00][00] v0.13.0.7 -> v0.13.0.7
[00017198][09 00][00] v3.0.0.10 -> v3.0.0.10
[00017266]Packet upgrade cancelled at version checking.
[00013535]========== 2016.05.16 07:35:19. boot(15) ============
[00013599]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x2857532b].
[00013671]Packet upgrade start...
[00013742]Packet checking...
[00013813]Packet vlink 01.08.0080 <-> 01.07.0060.
[00013880]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00013948]Done.
[00014015]Version checking[1]...
[00014133][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014234][03 06][00] v2.4.14.5 -> v2.4.14.5
[00014311][04 00][00] v1.44.0.0 -> v1.44.0.0
[00014460][11 00][00] v1.7.15.1 -> v1.7.15.1
[00014581][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014713][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014824][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014948][12 03][00] v1.10.0.0 -> v1.10.0.0
[00015106][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015232][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015402][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015510][19 00][00] v255.255.255.254 -> v1.0.8.96
[00015576][01 00][00] v1.30.5036 -> v1.30.5036
[00015648][01 01][00] v1.30.5036 -> v1.30.5036
[00015726][08 00][00] v0.13.0.7 -> v0.13.0.7
[00015807][09 00][00] v3.0.0.10 -> v3.0.0.10
[00015874]Packet upgrade cancelled at version checking.
[00013385]========== 2016.05.16 16:38:50. boot(15) ============
[00013447]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x2857532b].
[00013614]Packet upgrade start...
[00013681]Packet checking...
[00013743]Packet vlink 01.08.0080 <-> 01.07.0060.
[00013804]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00013866]Done.
[00013927]Version checking[1]...
[00014047][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014146][03 06][00] v2.4.14.5 -> v2.4.14.5
[00014213][04 00][00] v1.44.0.0 -> v1.44.0.0
[00014367][11 00][00] v1.7.15.1 -> v1.7.15.1
[00014510][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014610][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014735][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014850][12 03][00] v1.10.0.0 -> v1.10.0.0
[00015001][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015129][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015290][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015378][19 00][00] v255.255.255.254 -> v1.0.8.96
[00015443][01 00][00] v1.30.5036 -> v1.30.5036
[00015506][01 01][00] v1.30.5036 -> v1.30.5036
[00015588][08 00][00] v0.13.0.7 -> v0.13.0.7
[00015675][09 00][00] v3.0.0.10 -> v3.0.0.10
[00015736]Packet upgrade cancelled at version checking.
[00013442]========== 2016.05.16 17:35:46. boot(15) ============
[00013573]Packet upgrade start...
[00013653]Packet checking...
[00013722]Packet vlink 01.08.0080 <-> 01.07.0060.
[00013861]Done.
[00013928]Version checking[1]...
[00014029][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014129][03 06][00] v2.4.14.5 -> v2.4.14.5
[00014215][04 00][00] v1.44.0.0 -> v1.44.0.0
[00014350][11 00][00] v1.7.15.1 -> v1.7.15.1
[00014453][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014575][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014709][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014818][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014982][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015098][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015258][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015345][19 00][00] v255.255.255.254 -> v1.0.8.96
[00015409][01 00][00] v1.30.5036 -> v1.30.5036
[00015583][01 01][00] v1.30.5036 -> v1.30.5036
[00015675][08 00][00] v0.13.0.7 -> v0.13.0.7
[00015839]Packet upgrade cancelled at version checking.
[00013990]========== 2016.05.16 17:48:38. boot(15) ============
[00014064]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x2857532b].
[00014136]Packet upgrade start...
[00014208]Packet checking...
[00014282]Packet vlink 01.08.0080 <-> 01.07.0060.
[00014352]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00014426]Done.
[00014507]Version checking[1]...
[00014622][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014742][03 06][00] v2.4.14.5 -> v2.4.14.5
[00014821][04 00][00] v1.44.0.0 -> v1.44.0.0
[00014983][11 00][00] v1.7.15.1 -> v1.7.15.1
[00015122][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015250][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015366][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015522][12 03][00] v1.10.0.0 -> v1.10.0.0
[00015706][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015825][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015987][17 01][00] v1.0.2.7 -> v1.0.2.7
[00016077][19 00][00] v255.255.255.254 -> v1.0.8.96
[00016151][01 00][00] v1.30.5036 -> v1.30.5036
[00016214][01 01][00] v1.30.5036 -> v1.30.5036
[00016309][08 00][00] v0.13.0.7 -> v0.13.0.7
[00016397][09 00][00] v3.0.0.10 -> v3.0.0.10
[00016471]Packet upgrade cancelled at version checking.
[00380959]========== remo-con disconnect. boot(15) ============
[00381033]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x2857532b].
[00381106]Packet upgrade start...
[00381186]Packet checking...
[00381258]Packet vlink 01.08.0080 <-> 01.07.0060.
[00381332]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00381400]Done.
[00381471]Version checking[1]...
[00381577][03 05][00] v34.2.0.9 -> v34.2.0.9
[00381677][03 06][00] v2.4.14.5 -> v2.4.14.5
[00381751][04 00][00] v1.44.0.0 -> v1.44.0.0
[00381897][11 00][00] v1.7.15.1 -> v1.7.15.1
[00382006][12 00][00] v1.10.0.0 -> v1.10.0.0
[00382245][12 01][00] v1.10.0.0 -> v1.10.0.0
[00382346][12 02][00] v1.10.0.0 -> v1.10.0.0
[00382449][12 03][00] v1.10.0.0 -> v1.10.0.0
[00382621][15 00][00] v1.1.2.0 -> v1.1.2.0
[00382766][17 00][00] v1.1.1.7 -> v1.1.1.7
[00382932][17 01][00] v1.0.2.7 -> v1.0.2.7
[00383026][19 00][00] v255.255.255.254 -> v1.0.8.96
[00383095][01 00][00] v1.30.5036 -> v1.30.5036
[00383169][01 01][00] v1.30.5036 -> v1.30.5036
[00383253][08 00][00] v0.13.0.7 -> v0.13.0.7
[00383346][09 00][00] v3.0.0.10 -> v3.0.0.10
[00383421]Packet upgrade cancelled at version checking.
[00014856]========== remo-con disconnect. boot(15) ============
[00014927]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x017e4e1f].
[00015000]Packet upgrade start...
[00015082]Packet checking...
[00015152]Packet vlink 01.08.0080 <-> 01.07.0060.
[00015226]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00015296]Done.
[00015373]Version checking[1]...
[00015476][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015595][03 06][00] v2.4.14.5 -> v2.4.14.5
[00015671][04 00][00] v1.44.0.0 -> v1.44.0.0
[00015843][11 00][00] v1.7.15.1 -> v1.7.15.1
[00015961][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016069][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016190][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016320][12 03][00] v1.10.0.0 -> v1.10.0.0
[00016499][15 00][00] v1.1.2.0 -> v1.1.2.0
[00016603][17 00][00] v1.1.1.7 -> v1.1.1.7
[00016744][17 01][00] v1.0.2.7 -> v1.0.2.7
[00016830][19 00][00] v255.255.255.254 -> v1.0.8.96
[00016909][01 00][00] v1.30.5036 -> v1.30.5036
[00016980][01 01][00] v1.30.5036 -> v1.30.5036
[00017072][08 00][00] v0.13.0.7 -> v0.13.0.7
[00017170][09 00][00] v3.0.0.10 -> v3.0.0.10
[00017244]Packet upgrade cancelled at version checking.
[00014524]========== 2016.05.16 19:32:50. boot(15) ============
[00014593]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x2857532b].
[00014662]Packet upgrade start...
[00014742]Packet checking...
[00014813]Packet vlink 01.08.0080 <-> 01.07.0060.
[00014987]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00015063]Done.
[00015134]Version checking[1]...
[00015230][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015329][03 06][00] v2.4.14.5 -> v2.4.14.5
[00015411][04 00][00] v1.44.0.0 -> v1.44.0.0
[00020575][11 00][00] v1.7.15.1 -> v1.7.15.1
[00020702][12 00][00] v1.10.0.0 -> v1.10.0.0
[00020828][12 01][00] v1.10.0.0 -> v1.10.0.0
[00020962][12 02][00] v1.10.0.0 -> v1.10.0.0
[00021094][12 03][00] v1.10.0.0 -> v1.10.0.0
[00021268][15 00][00] v1.1.2.0 -> v1.1.2.0
[00021398][17 00][00] v1.1.1.7 -> v1.1.1.7
[00021559][17 01][00] v1.0.2.7 -> v1.0.2.7
[00021648][19 00][00] v255.255.255.254 -> v1.0.8.96
[00021727][01 00][00] v1.30.5036 -> v1.30.5036
[00021795][01 01][00] v1.30.5036 -> v1.30.5036
[00021892][08 00][00] v0.13.0.7 -> v0.13.0.7
[00021989][09 00][00] v3.0.0.10 -> v3.0.0.10
[00022062]Packet upgrade cancelled at version checking.
[00014875]========== remo-con disconnect. boot(15) ============
[00014947]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x017e4e1f].
[00015014]Packet upgrade start...
[00015091]Packet checking...
[00015165]Packet vlink 01.08.0080 <-> 01.07.0060.
[00015240]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00015311]Done.
[00015392]Version checking[1]...
[00015506][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015628][03 06][00] v2.4.14.5 -> v2.4.14.5
[00015711][04 00][00] v1.44.0.0 -> v1.44.0.0
[00015866][11 00][00] v1.7.15.1 -> v1.7.15.1
[00015995][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016115][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016246][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016358][12 03][00] v1.10.0.0 -> v1.10.0.0
[00016535][15 00][00] v1.1.2.0 -> v1.1.2.0
[00016654][17 00][00] v1.1.1.7 -> v1.1.1.7
[00016810][17 01][00] v1.0.2.7 -> v1.0.2.7
[00016906][19 00][00] v255.255.255.254 -> v1.0.8.96
[00016978][01 00][00] v1.30.5036 -> v1.30.5036
[00017054][01 01][00] v1.30.5036 -> v1.30.5036
[00017142][08 00][00] v0.13.0.7 -> v0.13.0.7
[00017366][09 00][00] v3.0.0.10 -> v3.0.0.10
[00017440]Packet upgrade cancelled at version checking.
