Rattling noise from prop
2976 26 2016-5-11
dr. D
Flight distance : 8699150 ft
Please check my inspire prop. It took only a minute of your time.
http://youtu.be/ctcIHwzzuGs
Any ideas? Are my props worn-out?
They've flewn 150 KM./ 100 Mile.
The bearings seems ok. It is only with attached prop. When I twisted it 180 degrees it gives less noise.
2016-5-11
Donnie
Flight distance : 3636782 ft
     I dont have a Microsoft account......  can you just post it some other way..... I find that the I pads work great for this task and automatically compress to make it  work.
Or post the video on you tube with a link in the description.
Is the prop making a funny noise ?  If you feel the props are even questionable I would replace them , also I would replace the Locking mechanism as well, I replace mine  3 times a year, it is inexpoensive and good insurance.  Be sure to blow out the motors with compressed air as well, I find that some dust and small debris seem to find there way in there .
Also check the blade tips at eye level during a hover, compare them to the others  ( use safety glasses ) Make sure they are in line and not out of alignment , a bent "Main"  shaft will cause  strange noises and wicked vibration  .  This is a task that was common with RC helicopters to get equal pitch out of the main rotor .
Have you had any tipovers that would cause damage to the Motors ?
One other note if you are going to replace the Props and locks, If you dont have the 1345T setup, get it, and dont use carbon fibre blades on the Inspire, they put to much strain on the locking mechanism during fast climbouts and braking.  On the Phantom series carbon fibre is ok but in my opinion not a good fit on Inspire, be sure to get Genuine DJI plastic blades. ( be sure to use lock tite on the screws for the Locking mechanism for the props)
donnie
2016-5-11
dr. D
Donnie Posted at 2016-5-11 15:19
I dont have a Microsoft account...... you really should just post the video if you want forum member ...
Hi Donnie, I tried that...
I'll see if I can change it.
2016-5-11
Donnie
dr. D Posted at 2016-5-11 08:24
Doctor D ! If you can that would be brilliant, I have a google account but  not Microsoft,
a video is always so helpful too, I would love to see it if you can get it up and running .
I will check back to see,  I did offer my ideas though, I hope they help.
Best regards- donnie
2016-5-11
dr. D
Donnie Posted at 2016-5-11 15:37
a vi ...
Donnie,
I will try but don't know yet how to upload from my iPad.
2016-5-11
dr. D
Donnie Posted at 2016-5-11 15:58
Test video of me Lads from Liverpool, John is a crack up in the beginning, I just am doing a test fr ...
Donnie, Thanks for your tips.
I am sick and tired trying to get a iPhone video working.
Maybe I'll try it later.
2016-5-11
RichJ53
Flight distance : 1837356 ft
While you are trying to make your video.
Please inspect your props and hubs for wear or damage. Take some photos and post them.
Try your spare props and see if it still makes noise. Please be aware that a bad bearing could be fine without loading.
Rich
2016-5-11
Donnie
dr. D Posted at 2016-5-11 09:48
Maybe I' ...
Dont worry about the video , just try again when you have time.
No worries- donnie
2016-5-11
dr. D
Donnie Posted at 2016-5-11 19:47
No worries- donnie
I did!
It should work now.
2016-5-11
Donnie
dr. D Posted at 2016-5-11 13:01
I did!
It should work now.
    Dr. D  WOW ! that is strange , I would  replace the locking mechanism and props for sure.
If you take another Prop off  the other side does it do it ? I think if you inspect the prop or the locking mechanism something is broken off.
I just did this on mine and found if the prop lock was not tight , I could get a similar sound .
Also take that locking mechanism apart and look for a crack in it , something is not right, I would not fly with that until I had new props and locks.
Let me know what you find, I am going to go with the Prop  Lock mechanism is broken, hairline crack and not getting it tight all the way.
Get yourself a quality T handle 2.0mm allen wrench and take that apart and inspect and replace !
good luck and let me know .
2016-5-11
dr. D
Donnie Posted at 2016-5-11 20:18
If you take an ...
Donnie, I just tried a new set props. The rattling is almost over.
I guess the props are worn-out but I can see no physical damage.
2016-5-11
Donnie
dr. D Posted at 2016-5-11 13:22
Donnie, I just tried a new set! No Rattling absolute nothing!
I guess the props are worn-out but I ...
I think I see the problem, look at the bottom of the prop, it is not shaped correctly ( The center hub is defomed or broken )  in this shot, take a look at it up close and see if it is deformed , maybe from heat or something during the molding process .
Let me know after you compare to others.
donnie
2016-5-11
dr. D
Hmm don't see any difference.
New and 'old' prop
New and 'old' prop
2016-5-11
Donnie
dr. D Posted at 2016-5-11 13:58
I thought I had it solved for sure, sorry Dr. D, can you take a quick pick of the Hub that is in question as well, only if you have a extra minute, it must be getting late out your way , I live in the USA, Michigan to be exact.
I wonder if it is just worn out and loose and you would not be able to tell unless you had a dial caliper.
This has me vexed !
donnie
2016-5-11
dr. D
Donnie Posted at 2016-5-11 21:11
I thought I had it solved for sure, sorry Dr. D, can you take a quick pick of the Hub that is in qu ...
No problem! Any help is welcome.
I just re-ensemble the hub. Nothing strange about it.
Any help from one of the DJI-guys? It feels I'm grounded...
My aircraft is less than three months old, never had an issue.
2016-5-11
DJI-Ken
Flight distance : 1515312 ft
That is strange,
I would just get some new installation kits. http://store.dji.com/product/ins ... er-installation-kit
In the meantime, try changing the locking mechanism to another motor and see if it still does it on the other motor.
2016-5-11
dr. D
DJI-Ken Posted at 2016-5-11 22:21
That is strange,
I would just get some new installation kits. http://store.dji.com/product/inspire-1 ...
Thanks Ken,
I'll try that.
There are more known cases on the internet. Can it still be a (lower)motor bearing?
As Rich said: 'Please be aware that a bad bearing could be fine without loading'.
How to check these bearings? There  is no unusual noise coming from the motor.
2016-5-11
DJI-Ken
dr. D Posted at 2016-5-12 04:44
Thanks Ken,
I'll try that.
i personally do not think it's a bearing because it only does it when the prop is on one way then putting the prop on 180 degrees the other way it doesn't do it. But the aircraft has a 1yr warranty and if it is an motor issue it would be covered under warranty.
If you cannot feel anything unusual when hand turning the motor it may not be a bearing.
2016-5-11
dr. D
DJI-Ken Posted at 2016-5-11 23:11
i personally do not think it's a bearing because it only does it when the prop is on one way then  ...
Ok thanks Ken, ordered two Hub sets.
In the meantime I was trying to get a temporary solution and I found out this:
I think that just a little space between the hub and the prop give this loud resonance.
Just two pieces of ordinary (sello) tape with a thickness of 0,1(!) mm. will help.
For there is no physical damage to the hub or prop it might be a permanent solution.
Taped HUB
 Taped HUB
2016-5-12
DJI-Ken
dr. D Posted at 2016-5-12 16:07
In the meantime I was trying to get a temporary solution and I ...
WOW, that's nice. Still, with the new hubs you'll have a full sense of security.
Good job finding a solution.
2016-5-12
Donnie
dr. D Posted at 2016-5-12 03:07
      Dr.  D I think that over time the Locking mechanism just wore out from braking and acceleration, I would be careful flying and avoid
hard braking and acceleration until the new locks arrive.  If you have a dial caliper it would be interesting to see how much wear between the
old and new one.
That sure was an interesting case for sure, You folks in the Netherlands have  Calm, re-assuring voices compared to  American's and Brit's.  LOL
All the best from the USA- donnie
2016-5-12
str1776
Flight distance : 22530 ft
That was great will use this lesson for future concerns  definitely    valuable demonstration !
Thank you
2016-5-12
noaches232
Just get new props.
2016-5-12
dr. D
That depends, with new props the rattling wasn't vanished.
The HUBS should be replaced (as well)
Or you can use some Tape...
2016-5-13
Hits9Nine
Here is my fix on this issue.  Hope this helps
2016-5-13
RichJ53
dr. D Posted at 2016-5-12 01:07
Looks like you need some new hubs.
Do not take a chance and just replace the bad parts, They do not cost much and you will be back to new condition again.....
I guess, you didn't  listen to anyone else's comments on here other than Donnie.  Next time I will not bother
Rich
2016-5-13
winterh103
Flight distance : 88301 ft
I just swapped out the 1345S hubs for the new 1345T. The red ones on mine both rattle and are looser than the white hubs. Bad design.
I'm going back to the 1345S hubs as I don't trust the new ones.
2016-5-22
