Try this (for fixing the 1.1.0.11 issue)OSMO_FC550_FW_V01.01.00.2...
2702 16 2016-5-12
wslam
For those experiencing issues with the OSMO Pro, I just installed the not yet official Firmware posted here: http://forum.dji.com/forum.php?m ... 3425&fromuid=156575
I am happy to report that it seems to have solved a few issues:
1) Firmware no longer says Unknown, now the firmware version is properly stated.
2) Audio now works
3) Settings now stick after power recycle (at least for the last two times)
It is now somewhat more functional...
2016-5-12
paull
Cheers for being the first tester for this. Good news. I will install tonight.
After three days for utterly useless support from DJI Europe, hopefully this issue is now fixed.
EU Support are still asking me to RMA for repair... Useless.
2016-5-12
wslam
It did take me 2 tries to get the firmware install though. You need to make sure the file name starts with OSMO, so get rid of (for fixing the 1.1.0.11 issue) from the filename.
2016-5-12
paull
Thanks for the tip. Will apply tonight.
2016-5-12
paull
I can also confirm that this fix works.
2016-5-12
R&L Aerial
Flight distance : 298100 ft
How does one open the file from Dropbox, windows says it can't????
2016-5-14
wslam
R&L Aerial  Posted at 2016-5-14 04:08
It should be a .bin firmware file. You download and copy that directly to your SD card and then follow the standard upgrade procedure.
2016-5-14
DJI-Adela
wslam Posted at 2016-5-12 22:59
It did take me 2 tries to get the firmware install though. You need to make sure the file name start ...
Hi,
Thanks for your feedback, I'm glad that it works and fixed your problem.
You're right!  "(for fixing the 1.1.0.11 issue)" is just a remark I wrote for you, when you upgrade the firmware, please rename the bin file by moving that remark.
2016-5-14
R&L Aerial
wslam Posted at 2016-5-14 13:08
It should be a .bin firmware file. You download and copy that directly to your SD card and then fo ...
How do I unzip it??
2016-5-15
wslam
You don't unzip it. The file downloaded should be a .bin file, just copy that to your SD card.
2016-5-15
R&L Aerial
wslam Posted at 2016-5-15 14:19
I've tried about 10 different ways and it will not work, very frustrating, waited months and months now there firmwares messed up, I give up
2016-5-15
DJI-Adela
R&L Aerial  Posted at 2016-5-16 03:06
I've tried about 10 different ways and it will not work, very frustrating, waited months and month ...
Hello!
What the exact problem do you have?
The "new" firmware bin file is only for fix the issue of v1.1.0.11.
2016-5-15
fans99859b57
DJI-Adela Posted at 2016-5-15 22:01
Hello!
Is there another firmware to fix this problem?  I bought an X5 adapter for my x5 camera to work on my Osmo but the firmware says unknown and I cannot update.
2017-11-23
fans99859b57 Posted at 2017-11-23 11:38
lease download the firmware of Osmo Pro to your SD card: https://www.dji.com/osmo-pro-and ... te_search#downloads
Then update the firmware via the steps below:
Before power on, keep pressing the Trigger and Record button at the same time, then press Power switch for about 5 seconds until the indicator blinks red and green alternatively.
A few minutes later, when the indicator becomes solid green, delete the firmware in SD card and reboot the Osmo Pro.
2017-11-24
fans99859b57
I tried this also and the light continued to blink red and green but never turned solid green.
2017-12-22
fans99859b57
DJI Mindy, I never got a response from you!!!
2018-1-6
jloma
New Zealand
can you please reupload file......i am facing the same proble with my xenmuse x5
2020-10-30
