joe
Flight distance : 3330620 ft
Hello,
I have been using the Inspire from day 1, and I have the i1 Pro, and the i1Raw. Once thing that I have noticed latly in the software is that the Go App is not saving the last camera settings when you reboot the aircraft. I leave the remote and Go App on, but when I reboot the aircraft, nothing is saved. What is not being saved, for example, I will be shooting in apature priority with a apature setting of say 6. Then when I reboot, the apature always returns to the lowest number the lens supports, and the focus is always way out of focus, so everytime I reboot, I have to refocus the cameras, go to the apature setting, and painfully move the apature to where I had it, and the pain part is that you can not just slid the slider over to the last setting as you have to stop at each stop setting for the iso to catch up, because if you do not stop at each stop setting, the slider will automaticly go back to the stop you skipped over.
If you are in manual mode, you have to change everything.
Another issue is that the right hand wheel that you can use the wheel through these setting, you have to click back over to apature, which would be nice if it would also keep apature selected, and sometime as your wheel thought, the selection will move over to the exposure setting, which will then goof your settings up.
Thanks
Joe
