PH Standard Need an Update to Fix the Update!
16830 22 2016-5-13
Sundance Kid
Flight distance : 1207 ft
My Standard is useless after the latest update and there appears to be no way to downgrade the firmware.
Note Full Bars!
Note Full Bars!
Stuck here-Can't downgrade
or this!
or this!
2016-5-13
DJI-Paladin
Flight distance : 2408 ft
Hello Sundance Kid, could you please post the hidden upgrade log here? The log could be found by the methods below:
1. Enable the option of viewing hidden files in your OS. Below are the websites where you can check how to show the hidden files in your PC.
For The Windows System:
http://windows.microsoft.com/en- ... den-files=windows-7
For The Mac System:
http://ianlunn.co.uk/articles/qu ... mac-os-x-mavericks/
2.Enter the root directory of the SD card, then find the hidden folder MISC and enter it. There is LOG folder in it.
3.The LOG txt file is under the LOG folder.
2016-5-13
Sundance Kid
Can't attach a txt file so here is the text of it.
First, a little background:
I live in an area on a hill with a lot of interference from various radio towers so I do not expect a lot of range. I have been able to go about 200 ft up and/or 1000 feet from my home point before I would see loss of wifi signal. With this update, as the pictures show, I loose image at much less distance than before. HOWEVER-I still have full bars showing in the app.
That's the first problem. The second problem is that I cannot downgrade the firmware. Why not?
[00322028]========== 2016.03.06 16:08:58. boot(1) ============
[00322147]Packet [C:\P3C_FW_V99.99.9999.bin] detected, card sn [0x9d6e2473].
[00322182]Packet upgrade start...
[00322218]Packet checking...
[00322256]Packet vlink 01.03.0050 <-> 01.02.0040.
[00322321]Done.
[00322361]Version checking[1]...
[00322392][01 00][00] v1.13.4312 -> v1.13.4312
[00322425][01 01][00] v1.13.4312 -> v1.13.4312
[00322476][04 00][00] v1.41.0.0 -> v1.41.0.0
[00322542][03 05][00] v34.2.0.9 -> v34.2.0.9
[00322626][03 06][00] v2.4.0.5 -> v2.4.10.7 need upgrade.
[00322703][09 00][00] v0.1.0.9 -> v0.1.1.0 need upgrade.
[00322807][12 00][00] v5.9.0.0 -> v5.9.0.0
[00322909][12 01][00] v5.9.0.0 -> v5.9.0.0
[00322990][12 02][00] v5.9.0.0 -> v5.9.0.0
[00323088][12 03][00] v5.9.0.0 -> v5.9.0.0
[00323202][11 00][00] v1.7.0.0 -> v1.8.0.0 need upgrade.
[00323236]Done.
[00325272]Waiting for user confirm...
[00335306]Timeout, start upgrade automatically.
[00335379]Firmware upgrading[1]...
[00335423][11 00] Firmware upgrade start...
[00383979][11 00] Firmware upgrade finished successfully.
[00384251][03 06] Firmware upgrade start...
[00750415][03 06] Firmware upgrade finished successfully.
[00750476][09 00] Firmware upgrade start...
[00776503][09 00] Firmware upgrade finish without reboot.
[00806537][09 00] Firmware upgrade finished successfully.
[00806571]Done.
[00806606]Version checking[2]...
[00806640][01 00][00] v1.13.4312 -> v1.13.4312
[00806684][01 01][00] v1.13.4312 -> v1.13.4312
[00806724][04 00][00] v1.41.0.0 -> v1.41.0.0
[00806805][03 05][00] v34.2.0.9 -> v34.2.0.9
[00806945][03 06][05] v2.4.10.7 -> v2.4.10.7
[00806990][09 00][05] v0.1.1.0 -> v0.1.1.0
[00807077][12 00][00] v5.9.0.0 -> v5.9.0.0
[00807156][12 01][00] v5.9.0.0 -> v5.9.0.0
[00807238][12 02][00] v5.9.0.0 -> v5.9.0.0
[00807343][12 03][00] v5.9.0.0 -> v5.9.0.0
[00807444][11 00][05] v1.8.0.0 -> v1.8.0.0
[00807475]Packet upgrade finish successfully.
[00087982]========== 2016.03.11 10:34:05. boot(15) ============
[00088115]Packet [C:\P3C_FW_V99.99.9999.bin] detected, card sn [0x9d6e2473].
[00088148]Packet upgrade start...
[00088183]Packet checking...
[00088221]Packet vlink 01.03.0050 <-> 01.02.0040.
[00088268]Record vlink 01.03.0050 <-> 01.02.0040 (flow = 0).
[00088303]Done.
[00088339]Version checking[1]...
[00088376][01 00][00] v1.13.4312 -> v1.13.4312
[00088417][01 01][00] v1.13.4312 -> v1.13.4312
[00088469][04 00][00] v1.41.0.0 -> v1.41.0.0
[00088542][03 05][00] v34.2.0.9 -> v34.2.0.9
[00088626][03 06][00] v2.4.10.7 -> v2.4.10.7
[00088702][09 00][00] v0.1.1.0 -> v0.1.1.0
[00088802][12 00][00] v5.9.0.0 -> v5.9.0.0
[00088907][12 01][00] v5.9.0.0 -> v5.9.0.0
[00089004][12 02][00] v5.9.0.0 -> v5.9.0.0
[00089102][12 03][00] v5.9.0.0 -> v5.9.0.0
[00089222][11 00][00] v1.7.0.0 -> v1.8.0.0 need upgrade.
[00089269]Done.
[00091305]Waiting for user confirm...
[00101341]Timeout, start upgrade automatically.
[00101421]Firmware upgrading[1]...
[00101482][11 00] Firmware upgrade start...
[00150058][11 00] Firmware upgrade finished successfully.
[00150092]Done.
[00150137]Version checking[2]...
[00150173][01 00][00] v1.13.4312 -> v1.13.4312
[00150210][01 01][00] v1.13.4312 -> v1.13.4312
[00150249][04 00][00] v1.41.0.0 -> v1.41.0.0
[00150324][03 05][00] v34.2.0.9 -> v34.2.0.9
[00150401][03 06][00] v2.4.10.7 -> v2.4.10.7
[00150457][09 00][00] v0.1.1.0 -> v0.1.1.0
[00150565][12 00][00] v5.9.0.0 -> v5.9.0.0
[00150649][12 01][00] v5.9.0.0 -> v5.9.0.0
[00150754][12 02][00] v5.9.0.0 -> v5.9.0.0
[00150831][12 03][00] v5.9.0.0 -> v5.9.0.0
[00150982][11 00][05] v1.8.0.0 -> v1.8.0.0
[00151018]Packet upgrade finish successfully.
[00212006]========== remo-con disconnect. boot(15) ============
[00212047]Packet [C:\P3C_FW_V99.99.9999.bin] detected, card sn [0x9d6e2473].
[00212084]Packet upgrade start...
[00212128]Packet checking...
[00212166]Packet vlink 01.04.0060 <-> 01.03.0050.
[00212203]Record vlink 01.03.0050 <-> 01.02.0040 (flow = 0).
[00212327]Done.
[00212365]Version checking[1]...
[00212403][01 00][00] v1.13.4312 -> v1.14.4920 need upgrade
[00212437][01 01][00] v1.13.4312 -> v1.14.4920 need upgrade
[00212494][04 00][00] v1.41.0.0 -> v1.41.0.0
[00212577][03 05][00] v34.2.0.9 -> v34.2.0.9
[00212655][03 06][00] v2.4.10.7 -> v2.4.13.0 need upgrade.
[00212706][09 00][00] v0.1.1.0 -> v0.1.1.0
[00212815][12 00][00] v5.9.0.0 -> v5.9.0.0
[00212923][12 01][00] v5.9.0.0 -> v5.9.0.0
[00213018][12 02][00] v5.9.0.0 -> v5.9.0.0
[00213116][12 03][00] v5.9.0.0 -> v5.9.0.0
[00213236][11 00][00] v1.8.0.0 -> v1.8.0.0
[00213378][11 01][00] v1.8.0.0 -> v2.0.0.32, firmware v1.8.0.0 not support.
[00213415][11 01][00] v1.8.0.0 -> v2.0.0.32
[00213460]Done.
[00215497]Waiting for user confirm...
[00225533]Timeout, start upgrade automatically.
[00225608]Firmware upgrading[1]...
[00241747][01 00] Firmware upgrade start...
[00013942][01 00] Firmware upgrade finished successfully.
[00013986]Done.
[00014026]Packet [C:\P3C_FW_V99.99.9999.bin] resumed, card sn [0x9d6e2473].
[00014064]Packet vlink 01.04.0060 <-> 01.03.0050.
[00014109]Record vlink 01.03.0050 <-> 01.02.0040 (flow = 0).
[00014150]Version checking[2]...
[00014190][01 00][05] v1.14.4920 -> v1.14.4920
[00014226][01 01][00] v1.13.4312 -> v1.14.4920 need upgrade
[00014272][04 00][00] v1.41.0.0 -> v1.41.0.0
[00014335][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014421][03 06][00] v2.4.10.7 -> v2.4.13.0 need upgrade.
[00014477][09 00][00] v0.1.1.0 -> v0.1.1.0
[00014573][12 00][00] v5.9.0.0 -> v5.9.0.0
[00014677][12 01][00] v5.9.0.0 -> v5.9.0.0
[00014775][12 02][00] v5.9.0.0 -> v5.9.0.0
[00014876][12 03][00] v5.9.0.0 -> v5.9.0.0
[00014993][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015119][11 01][00] v1.8.0.0 -> v2.0.0.32, firmware v1.8.0.0 not support.
[00015159][11 01][00] v1.8.0.0 -> v2.0.0.32
[00015195]Done.
[00015228]Firmware upgrading[2]...
[00015390][01 01] Firmware upgrade start...
[00045690][01 01] Firmware upgrade finished successfully.
[00046059][03 06] Firmware upgrade start...
[00412333][03 06] Firmware upgrade finished successfully.
[00412371]Done.
[00412406]Version checking[3]...
[00412441][01 00][05] v1.14.4920 -> v1.14.4920
[00412488][01 01][05] v1.14.4920 -> v1.14.4920
[00412531][04 00][00] v1.41.0.0 -> v1.41.0.0
[00412597][03 05][00] v34.2.0.9 -> v34.2.0.9
[00412674][03 06][05] v2.4.13.0 -> v2.4.13.0
[00412725][09 00][00] v0.1.1.0 -> v0.1.1.0
[00412835][12 00][00] v5.9.0.0 -> v5.9.0.0
[00412933][12 01][00] v5.9.0.0 -> v5.9.0.0
[00413037][12 02][00] v5.9.0.0 -> v5.9.0.0
[00413136][12 03][00] v5.9.0.0 -> v5.9.0.0
[00413262][11 00][00] v1.8.0.0 -> v1.8.0.0
[00413374][11 01][00] v1.8.0.0 -> v2.0.0.32, firmware v1.8.0.0 not support.
[00413407][11 01][00] v1.8.0.0 -> v2.0.0.32
[00413442]Packet upgrade finish successfully.
[00066106]========== remo-con disconnect. boot(15) ============
[00066141]Packet [C:\P3C_FW_V99.99.9999.bin] detected, card sn [0x9d6e2473].
[00066178]Packet upgrade start...
[00066216]Packet checking...
[00066254]Packet vlink 01.04.0060 <-> 01.03.0050.
[00066288]Record vlink 01.04.0060 <-> 01.03.0050 (flow = 0).
[00066322]Done.
[00066358]Version checking[1]...
[00066392][01 00][00] v1.14.4920 -> v1.14.4920
[00066434][01 01][00] v1.14.4920 -> v1.14.4920
[00066476][04 00][00] v1.41.0.0 -> v1.41.0.0
[00066561][03 05][00] v34.2.0.9 -> v34.2.0.9
[00066638][03 06][00] v2.4.13.0 -> v2.4.13.0
[00066694][09 00][00] v0.1.1.0 -> v0.1.1.0
[00066774][12 00][00] v5.9.0.0 -> v5.9.0.0
[00066851][12 01][00] v5.9.0.0 -> v5.9.0.0
[00066939][12 02][00] v5.9.0.0 -> v5.9.0.0
[00067054][12 03][00] v5.9.0.0 -> v5.9.0.0
[00067177][11 00][00] v1.7.0.0 -> v1.8.0.0 need upgrade.
[00067296][11 01][00] v1.7.0.0 -> v2.0.0.32, firmware v1.7.0.0 not support.
[00067330][11 01][00] v1.7.0.0 -> v2.0.0.32
[00067368]Done.
[00069401]Waiting for user confirm...
[00079436]Timeout, start upgrade automatically.
[00079507]Firmware upgrading[1]...
[00079633][11 00] Firmware upgrade start...
[00127635][11 00] Firmware upgrade finished successfully.
[00127670]Done.
[00127705]Version checking[2]...
[00127749][01 00][00] v1.14.4920 -> v1.14.4920
[00127784][01 01][00] v1.14.4920 -> v1.14.4920
[00127826][04 00][00] v1.41.0.0 -> v1.41.0.0
[00127902][03 05][00] v34.2.0.9 -> v34.2.0.9
[00127979][03 06][00] v2.4.13.0 -> v2.4.13.0
[00128035][09 00][00] v0.1.1.0 -> v0.1.1.0
[00128140][12 00][00] v5.9.0.0 -> v5.9.0.0
[00128247][12 01][00] v5.9.0.0 -> v5.9.0.0
[00128331][12 02][00] v5.9.0.0 -> v5.9.0.0
[00128429][12 03][00] v5.9.0.0 -> v5.9.0.0
[00128560][11 00][05] v1.8.0.0 -> v1.8.0.0
[00128679][11 01][00] v1.8.0.0 -> v2.0.0.32, firmware v1.8.0.0 not support.
[00128721][11 01][00] v1.8.0.0 -> v2.0.0.32
[00128769]Packet upgrade finish successfully.
[00076206]========== remo-con disconnect. boot(15) ============
[00076245]Packet [C:\P3C_FW_V99.99.9999.bin] detected, card sn [0x9d6e2473].
[00076287]Packet upgrade start...
[00076329]Packet checking...
[00076376]Packet vlink 01.04.0060 <-> 01.03.0050.
[00076413]Record vlink 01.04.0060 <-> 01.03.0050 (flow = 0).
[00076457]Done.
[00076495]Version checking[1]...
[00076534][01 00][00] v1.14.4920 -> v1.14.4920
[00076575][01 01][00] v1.14.4920 -> v1.14.4920
[00076623][04 00][00] v1.41.0.0 -> v1.41.0.0
[00076702][03 05][00] v34.2.0.9 -> v34.2.0.9
[00076800][03 06][00] v2.4.13.0 -> v2.4.13.0
[00076863][09 00][00] v0.1.1.0 -> v0.1.1.0
[00076949][12 00][00] v5.9.0.0 -> v5.9.0.0
[00077034][12 01][00] v5.9.0.0 -> v5.9.0.0
[00077121][12 02][00] v5.9.0.0 -> v5.9.0.0
[00077226][12 03][00] v5.9.0.0 -> v5.9.0.0
[00077342][11 00][00] v1.7.15.1 -> v1.8.0.0 need upgrade.
[00077464][11 01][00] v1.7.15.1 -> v2.0.0.32, firmware v1.7.15.1 not support.
[00077503][11 01][00] v1.7.15.1 -> v2.0.0.32
[00077543]Done.
[00079581]Waiting for user confirm...
[00089624]Timeout, start upgrade automatically.
[00089699]Firmware upgrading[1]...
[00089749][11 00] Firmware upgrade start...
[00138535][11 00] Firmware upgrade finished successfully.
[00138575]Done.
[00138613]Version checking[2]...
[00138649][01 00][00] v1.14.4920 -> v1.14.4920
[00138695][01 01][00] v1.14.4920 -> v1.14.4920
[00138738][04 00][00] v1.41.0.0 -> v1.41.0.0
[00138818][03 05][00] v34.2.0.9 -> v34.2.0.9
[00138903][03 06][00] v2.4.13.0 -> v2.4.13.0
[00139007][09 00][00] v0.1.1.0 -> v0.1.1.0
[00139098][12 00][00] v5.9.0.0 -> v5.9.0.0
[00139214][12 01][00] v5.9.0.0 -> v5.9.0.0
[00139323][12 02][00] v5.9.0.0 -> v5.9.0.0
[00139431][12 03][00] v5.9.0.0 -> v5.9.0.0
[00139561][11 00][05] v1.8.0.0 -> v1.8.0.0
[00139680][11 01][00] v1.8.0.0 -> v2.0.0.32, firmware v1.8.0.0 not support.
[00139716][11 01][00] v1.8.0.0 -> v2.0.0.32
[00139753]Packet upgrade finish successfully.
[00128139]========== 2016.04.07 08:43:07. boot(15) ============
[00128176]Packet [C:\P3C_FW_V99.99.9999.bin] detected, card sn [0x9d6e2473].
[00128213]Packet upgrade start...
[00128255]Packet checking...
[00128293]Packet vlink 01.05.0070 <-> 01.04.0060.
[00128328]Record vlink 01.04.0060 <-> 01.03.0050 (flow = 0).
[00128366]Done.
[00128401]Version checking[1]...
[00128444][01 00][00] v1.14.4920 -> v1.14.4920
[00128481][01 01][00] v1.14.4920 -> v1.14.4920
[00128523][04 00][00] v1.41.0.0 -> v1.44.0.0 need upgrade.
[00128616][03 05][00] v34.2.0.9 -> v34.2.0.9
[00129634][03 06][00] v2.4.13.0 -> v2.4.14.5 need upgrade.
[00129697][09 00][00] v0.1.1.0 -> v0.1.1.0
[00129779][12 00][00] v5.9.0.0 -> v5.9.0.0
[00129877][12 01][00] v5.9.0.0 -> v5.9.0.0
[00129975][12 02][00] v5.9.0.0 -> v5.9.0.0
[00130075][12 03][00] v5.9.0.0 -> v5.9.0.0
[00130199][11 00][00] v1.8.0.0 -> v1.8.0.0
[00130318][11 01][00] v1.8.0.0 -> v2.0.0.32, firmware v1.8.0.0 not support.
[00130357][11 01][00] v1.8.0.0 -> v2.0.0.32
[00130393]Done.
[00132428]Waiting for user confirm...
[00142464]Timeout, start upgrade automatically.
[00142537]Firmware upgrading[1]...
[00142779][03 06] Firmware upgrade start...
[00519810][03 06] Firmware upgrade finished successfully.
[00519873][04 00] Firmware upgrade start...
[00577640][04 00] Firmware upgrade finished successfully.
[00577678]Done.
[00577715]Version checking[2]...
[00577751][01 00][00] v1.14.4920 -> v1.14.4920
[00577791][01 01][00] v1.14.4920 -> v1.14.4920
[00577835][04 00][05] v1.44.0.0 -> v1.44.0.0
[00577908][03 05][00] v34.2.0.9 -> v34.2.0.9
[00577986][03 06][05] v2.4.14.5 -> v2.4.14.5
[00578036][09 00][00] v0.1.1.0 -> v0.1.1.0
[00578120][12 00][00] v5.9.0.0 -> v5.9.0.0
[00578231][12 01][00] v5.9.0.0 -> v5.9.0.0
[00578348][12 02][00] v5.9.0.0 -> v5.9.0.0
[00578469][12 03][00] v5.9.0.0 -> v5.9.0.0
[00578587][11 00][00] v1.8.0.0 -> v1.8.0.0
[00578706][11 01][00] v1.8.0.0 -> v2.0.0.32, firmware v1.8.0.0 not support.
[00578743][11 01][00] v1.8.0.0 -> v2.0.0.32
[00578784]Packet upgrade finish successfully.
[00288144]========== 2016.05.11 14:43:40. boot(15) ============
[00288190]Packet [C:\P3C_FW_V99.99.9999.bin] detected, card sn [0x9d6e2473].
[00288231]Packet upgrade start...
[00288279]Packet checking...
[00288321]Packet vlink 01.06.0080 <-> 01.05.0070.
[00288364]Record vlink 01.05.0070 <-> 01.04.0060 (flow = 0).
[00288405]Done.
[00288449]Version checking[1]...
[00288488][01 00][00] v1.14.4920 -> v1.14.4920
[00288535][01 01][00] v1.14.4920 -> v1.14.4920
[00288590][04 00][00] v1.44.0.0 -> v1.44.0.0
[00288663][03 05][00] v34.2.0.9 -> v34.2.0.9
[00288761][03 06][00] v2.4.14.5 -> v2.4.15.5 need upgrade.
[00288820][09 00][00] v0.1.1.0 -> v0.1.1.0
[00288910][12 00][00] v5.9.0.0 -> v5.9.0.0
[00289020][12 01][00] v5.9.0.0 -> v5.9.0.0
[00289128][12 02][00] v5.9.0.0 -> v5.9.0.0
[00289253][12 03][00] v5.9.0.0 -> v5.9.0.0
[00289357][11 00][00] v1.8.0.0 -> v1.8.0.0
[00289482][11 01][00] v1.8.0.0 -> v2.0.0.32, firmware v1.8.0.0 not support.
[00289527][11 01][00] v1.8.0.0 -> v2.0.0.32
[00289570]Done.
[00291612]Waiting for user confirm...
[00301655]Timeout, start upgrade automatically.
[00301850]Firmware upgrading[1]...
[00302148][03 06] Firmware upgrade start...
[00658755][03 06] Firmware upgrade finished successfully.
[00658794]Done.
[00658835]Version checking[2]...
[00658886][01 00][00] v1.14.4920 -> v1.14.4920
[00658927][01 01][00] v1.14.4920 -> v1.14.4920
[00659004][04 00][00] v1.44.0.0 -> v1.44.0.0
[00659087][03 05][00] v34.2.0.9 -> v34.2.0.9
[00659185][03 06][05] v2.4.15.5 -> v2.4.15.5
[00659253][09 00][00] v0.1.1.0 -> v0.1.1.0
[00659366][12 00][00] v5.9.0.0 -> v5.9.0.0
[00659464][12 01][00] v5.9.0.0 -> v5.9.0.0
[00659553][12 02][00] v5.9.0.0 -> v5.9.0.0
[00659647][12 03][00] v5.9.0.0 -> v5.9.0.0
[00659765][11 00][00] v1.8.0.0 -> v1.8.0.0
[00659885][11 01][00] v1.8.0.0 -> v2.0.0.32, firmware v1.8.0.0 not support.
[00659926][11 01][00] v1.8.0.0 -> v2.0.0.32
[00659980]Packet upgrade finish successfully.
2016-5-14
reinzneal
Flight distance : 29715 ft
Indonesia
The Steps :
1. Download the firmware at http://phantomhelp.com/Mobile/Phantom-3-Standard/#FirmwareArchive and select the fw that you want .bin file format
2. Insert the file to sd card, outside folder, and must be the only one .bin file format
3. Turn on the RC and the drone without sd card until it connect (RC and Drone)
4. Connect to DJI GO App (to see downgrade status stay at front page of the app)
5. Insert the sd card. Then the downgrade process is starting and rear led will turn to yellow and there will be beep sound from the drone (it is normal). See at DJI GO app, there will be status bar show the downgrade process. If the rear led becomes green it means the process is complete, you also can see the succes notice at DJI GO App.
6. Restart the RC and Drone, connect DJI GO App, check the FW. Finish.
I hope it can help the issue of 1.6.80 firmware for Phantom 3 Standard
NOTE : DO IT WITH YOUR OWN RISK!
2016-5-16
Sundance Kid
REINZNEAL,
I don't know who you are or where you are but I sure owe you big. I followed the above instruction and I was back to 1.5.7.0 and in the air in a matter of minutes. This completely solved my problem.
I don't think I can say THANK YOU big or bold enough. You're awesome!
2016-5-16
Sundance Kid
RE: PH Standard Need an Update to Fix the Update! **SOLVED**
Read Above for solution.
2016-5-16
pvb.samuel
Portugal
That just appeared when you make the last firmware uptade?
2016-5-16
Sundance Kid
Yes, At very short range. I Never saw it before the update.
2016-5-16
gerardorejeg
Flight distance : 120141 ft
Sundance Kid Posted at 2016-5-16 16:37
Thank you Sundance Kid... I must say I am a little hesitant to try that.. since I just bought it.. you know.. but i will look into that if this thing keeps losing signal... thanks again brother
2016-5-16
Mr.buGSy
Flight distance : 820712 ft
Sweden
Hi Sundance
I have the same issue with my P3P. Since the latest firmware upgrade 1.8. It happens when the drone is no more than 10m from me. I force-quit the app and restart it, the image comes back. This needs to be fixed DJI, yesterday!
Another thread with same issue http://forum.dji.com/forum.php?m ... mp;page=1#pid406792
2016-5-16
Sundance Kid
Hi Mr.buGSy,
I'm not sure down grading your firmware would help or not. I did previously have the same problem you are having and the solution was on this link. -->> I would try this first - http://forum.dji.com/thread-48448-1-1.html
2016-5-16
gerardorejeg
Sundance Kid Posted at 2016-5-16 18:34
Hi Mr.buGSy,
I'm not sure down grading your firmware would help or not. I did previously have the sa ...
do you guys fly in airplane mode on? i am trying that now just to eliminate variables and discard the possibility that my phone's signal is interfering with the antena.,, since it it right next to it when set our phones on the holder,, what are your thoughts?  i tried it and so far i havent gotten the rc signal lost message
2016-5-16
Sundance Kid
Nope. iPad mini 4. No sim card so no cellular. everything else is on.
2016-5-16
gerardorejeg
Sundance Kid Posted at 2016-5-16 19:20
I see...   well..  it was just a try..
2016-5-16
reinzneal
Indonesia
Sundance Kid Posted at 2016-5-17 02:46
REINZNEAL,
I don't know who you are or where you are but I sure owe you big. I followed the above in ...
You're welcome, glad it can help you
2016-5-17
Mr.buGSy
Sweden
gerardorejeg Posted at 2016-5-17 01:08
do you guys fly in airplane mode on? i am trying that now just to eliminate variables and discard  ...
I tried the airplane mod but it happened again. I have never had this issue prior to the firmware upgrade. I usually fly with airplane mode on – if and when I'm using the iPhone; just to avoid interruption with a phone call.
2016-5-17
matheusalcantar
Brazil
I'm with the same problem after updating for 1.6.80.
I think thats a firmware bug. They need to repair!
2016-5-30
phra
Panama
Same here! Tried calibrating everything and had the same issue! Thanks to Reinzneal I rolled back the firmware without issues and have perfect image transmission!
DJI has to adress this right away
2016-5-31
vu.q.le
Banned
2016-5-31
piersmolenaar
Singapore
reinzneal Posted at 2016-5-17 02:40
The Steps :
1. Download the firmware at http://phantomhelp.com/Mobile/Phantom-3-Standard/#FirmwareA ...
Hi, if this chat is still active I have a question about step 2 do I replace the file .bin or what?
2016-6-9
piersmolenaar
Singapore
The Steps :
HOLY sh** it worked I can't I've looked for a solution everywhere I don't know what to say.
Thank You
2016-6-9
kkaranta
Flight distance : 180883 ft
Greece
piersmolenaar@m Posted at 2016-6-9 11:38
Hi, if this chat is still active I have a question about step 2 do I replace the file .bin or what ...
Step 2 means: Format the SD card and copy in the root directory only the .bin file. Attention only one .bin file and format the SD card through DJI Go application or to your PC as FAT32.
2016-6-9
franciszorrilla
Thailand
guys what does it mean when my version is 1.5.70+ and app is 2.8.1
i also have the same issue of weak signal transmission and lost signal with my P3S..
do i still have to DG or just wait for fix from DJI?
2016-6-9
