M100 gps mounting value does not store, assistant 2
908 2 2016-5-29
Pizmo75
Flight distance : 910735 ft
Hello, when I connect my m100 to the pc to flowwing hapens:
I put in the gps mount values in: x, y and z axis. Turn everything off, than on again. Only the x and y axis are stored, NOT the z axis.
I do see the green puck on the screen to move to the position when entering the values, when goind to a different page it did not save. Why is this?
2016-5-29
Pizmo75
This only happens with dji assistant 2 v1.0.4. I downgraded to v1.0.3 and this problem seems to be solved.
DJI?
2016-5-29
mail
Flight distance : 775781 ft
Hi,
where can I find the v1.0.3. I have the problem, that I can't set values above -128mm but my GPS-Module is on the top so the height is -235mm.
Thanks
2016-6-10
