hamid.ebrahimi6
Hello
may be for you also happened , Failure IOSD mark II .
Failure :
1.Not connected to a PC (computer can not detect)
2.Video output is not
solution :
open the IOSD frame, After opening, SD card out of the slot and discard.
To do this you need a cutter , To remove the Glues Silicone.
You can replace the SD card 4 GB, 8 GB of SD card use.
Congratulations you've been able to Debugging.
And do not need to spend money to repair send.
