DJI-Jamie
Flight distance : 112405 ft
So as of right now, here are some things you can do to ensure that there is a solid Lightbridge connection between your aircraft and RC:
Reset your RC using the following button commands:
- Turn on the controller, and leave the aircraft off.
- Press and hold C1, C2, and Shutter on the controller, which will generate a quick audio queue, then turn the controller off while still holding the buttons.
- When you turn the RC back on, this should remove any presets that could be hindering the transmission signal to the aircraft.
After that I would recommend relinking the RC to the aircraft using the instructions on page 28 of the manual.
As far as app related troubleshooting, please update to the latest DJI Go app for the iOS (2.8.3) and have the following settings:
-Enable Hardware Decoding
-Reduce the Transmission Quality to the lowest setting
For any potential drifting issues, I would recommend an IMU calibration before you perform another compass calibration.
Please let me know if you see any changes. |
