Donnie
Flight distance : 3636782 ft
What can happen sometimes is that the 'Video Transmission Module" can become corrupted, this does not always happen and I am not sure why , but it can if you have the RC Transmitter on when updating the Aircraft. ( conflicting data from the RC and the Update perhaps, not sure 100% , I just know it can screw it up )
Also be sure to always delete the SD card so that you dont have the update in the bird and turn on the aircraft, wipe the SD card and format it, I keep my format SD seperate of my Recording SD cards )
The best way to see if this is indeed the problem is to re -load 1.8 to the Aircraft ( Just Like you did originally ) This will only take a short period of time because it is already loaded, then take the SD card out and read the hidden files. I will leave a link to how to do this. I hope you have a PC, if you have a MAC you must look online for directions to view hidden files. ( MAKE SURE RC IS OFF THIS TIME )
Once you do that , if you have on line 0800 and 1500 "No Device Detected " then you must send it in for repair, I have not seen any rollback work to fix this.
Before we get to worried, are you updated on both the aircraft and the RC Transmitter ? If you are not the system wont work either, so make sure you are updated and then do the hidden file procedure and get back to me.
http://forum.dji.com/thread-44546-1-1.html
Hope this helps
donnie
