Hi I am looking for somebody to fit a Lightbridge 2 to an S900. The S900 currently has the 5.8ghz setup.
If anyone can help please respond. I'm based up in Lancashire UK but will travel.
What is the problem? Lightbridge 2 very easy to set up, you refer to 5.8 is this your existing video link? If so you won't need it control and video come through on the lightbridge controller, if you need anymore info get back to me
You definitely want to start reading up on the Lightbridge 2 manual, which does provide a diagram on how to connect to the compatible flight controllers and gimbals. It would help to know that flight controller and gimbal you use to ensure that they are compatible. http://dl.djicdn.com/downloads/l ... _Manual_en_V1.2.pdf
If you happen to use an A2 and a GH4 gimbal, here's a video that shows how to install LB2, keep in mind that you would need to get a CANBus Hub for any of the recommended Z15 gimbals:
Hi Apologies the flight control is Wookong M Controllers are Futaba Gimbal is Zenmuse for Panasonic G4. It's my understanding that when using the Lightbridge 2 then that is the controller for the aircraft? I also have the Phantom 3 pro which has swayed me to the Lightbridge for the S900 (app, great video link etc)
Hi when you buy lightbridge 2 you will have a controller similar to inspire you control craft with it,you will not require the futaba and all your video feed,telemetry etc will be shown on a tablet/phone via Dji go app
