mail
Flight distance : 775781 ft
Hi,
I want to set up an Matrice 100. My SAT-Antenna is on the second Bay over the battery-compartment. Because ot the Guidance-System it's not possible to mount the GPS lower. When I want to make the Setup in the DJI Assistant 2 v.1.0.4 I can't set Z-Axis-Values more than -128mm. The GPS-Antenna is on -235mm. Any Ideas how to set a higher value? The Matrice 100 is on Firmware v.1.3.1.00.
Thanks for your help
