Hi, one of my props wasn't spinning properly after a VERY minor crash. I noticed a burning smell coming from it and after contacting my local supplier, I was advised to replace the motor. I ordered one that day, but on opening the Phantom, I noticed there was smoke damage on the upper case from above the PCB and noticed some damage to the board. I installed the new motor anyway to see if it worked, but it did the same as before, so the ESC has obviously gone.
My problem is, I can't seem to work out what version ESC I need. The leaflet with the new motor stated that version 2 would have 'VER. 2' by the barcode, but there isn't. There is a V2 printed on the circuit board elsewhere. I'm hoping I've ordered the correct motor too - I've attached photos of the original and the new one along with ESC pics.
Could someone please help me identify what I need to order. I'm pretty sure I know, but just want to double check! Thank you massively in advance!!
The pics are: Original motor, replacement motor, top half of the damaged ESC, underside barcode of the P2 and the other end of the ESC
Jamie
Original motor I'm guessing a 2312
Barcode under phantom
bottom half of ESC
