Gimble not centered....
2840 10 2016-6-13
dentin11
Flight distance : 155646 ft
I noticed today that my gimble is not in straight on my X5 Pro, there is no drifting,  its position is off center.  The camera is not in the neutral position.
I did a gimbal calibration,  but it didn't help.  When looking directly down on the bird, the camera/gimbal is not aligned with the nose of the bird,  slightly to the left approx an 1/2 inch.
Any advice?
2016-6-13
alfredosuna
Mexico
We have the same problem, we update from x3 to x5, if we plug the x3 is centered with nose of the inspire, but when we plug the x5 and make the calibration is slightly pointing to the right.
2016-6-16
DJI-Jamie
Flight distance : 112405 ft
For clarification, could you provide your whole set up? Have you tried an IMU calibration, then a Gimbal calibration in that order to try to resolve the issue? Did you notice after a firmware update, a hard landing or long term storage?
2016-6-16
DJI-Jamie
alfredosuna Posted at 2016-6-16 23:12
We have the same problem, we update from x3 to x5, if we plug the x3 is centered with nose of the in ...
Have you also tried an IMU calibration, then a Gimbal calibration in that order to try to resolve the issue?
2016-6-16
alfredosuna
Mexico
DJI-Jamie Posted at 2016-6-16 23:55
Have you also tried an IMU calibration, then a Gimbal calibration in that order to try to resolve  ...
Thanks for the answer DJI-Jamie... yes we did the IMU an gimbal calibration, we do them every update, we did both and the compas calibration as well yesterday, and still is turn just a little to the right. It's not the end of the world, the bird is working fine.
2016-6-16
DJI-Jamie
alfredosuna Posted at 2016-6-17 01:48
Thanks for the answer DJI-Jamie... yes we did the IMU an gimbal calibration, we do them every upda ...
Glad to hear, minute deviations can address themselves as firmware updates improve gimbal stability. Out of curiosity, do you use the Inspire as a single operator or as a dual operator? If you have a Slave remote, have you tried calibrating the RC to ensure that the midpoint is reading center for the gimbal controls?
2016-6-16
dentin11
Gimbal is fine now,  did IMU and Gimbal calibration
thanks!
2016-6-17
DJI-Jamie
dentin11 Posted at 2016-6-18 14:04
thanks!
I'm glad to hear you're all good to go.
2016-6-21
Drone Bandits 9
Flight distance : 2667625 ft
Hello I have an Inspire 1 Pro Black which I upgraded to a Raw an I am having the same issue as all above. The camera is not centered and it’s about 10 degrees to the right. I am 100% upgraded and have tried the following:
IMU Calibration
Compass Calibration
Checked all contacts to make sure there is no dirt or damage
The gimbal is perfectly balances
And still the camera sits to the right.
I took a second X5R and it does the same thing sits 10 degrees to the right.
I took my X5 camera and it centers perfectly. I’m very frustrated any help will be greatly appreciated.
2017-8-1
Upthedowns
Flight distance : 288353 ft
Drone Bandits 9 Posted at 2017-8-1 13:02
IMU Calibration
Compass Calibration
You don't mention a gimbal cal.  Have you done one?  Ensure the aircraft is completely levelled.
2017-8-5
Drone Bandits 9
Upthedowns Posted at 2017-8-5 12:12
Yes sorry I did that as well
2017-8-5
