A3 Gain Settings
9820 27 2016-6-25
bcdebusk
For that S1000, here are the A2 suggested gains:
For A2 flight controller
Basic: Roll 120%, Pitch 120%, Yaw 120%
Attitude: Roll 170%, Pitch 170%, Vertical 120%
For WooKong-M flight controller
Basic: Roll 180%, Pitch 180%, Yaw 120%
Attitude: Roll 180%, Pitch 180%, Vertical 120%
What are the corresponding gains for the A3?
I'm at the default now (90) and still getting overshoot on Aleron and Elevator inputs.
Thanks in advance.
2016-6-25
bcdebusk
And here are my current gain settings.  This is an A3 -- not an A2.
On an A2 these numbers would be significantly higher.
2016-6-25
Tahoe_Ed
Flight distance : 2605 ft
Have you tried to lower your sensitivity settings.
2016-6-25
bcdebusk
Tahoe_Ed Posted at 2016-6-25 20:09
So leave the gains of 90 alone and make the sticks less sensitive?
I'll confess, I'm a cleanflight/Arducopter guy.  I understand PID, but I don't fully understand DJI gains.
2016-6-25
bcdebusk
No one willing to toss-out some A3 gains?
A3 / S1000+ / Z15-A7 / 2.5kg battery
I'm at 90 now.  Not sure which way to take them.
2016-6-29
DJI-Jamie
Flight distance : 112405 ft
bcdebusk Posted at 2016-6-30 10:44
Once you get past the default gains settings, the changes would be at your discretion. When you're making any Gains adjustments, it's good to do so at 5% increments. Just to clarify, are you using Lightbridge 2 for your RC, or a 3rd party RC?
2016-6-30
bcdebusk
DJI-Jamie Posted at 2016-6-30 16:21
Once you get past the default gains settings, the changes would be at your discretion. When you're ...
I'm using an LB2.
It flies fairly smoothly with gains at 90.  But when remove elevator or aileron, I get a little bit of "snap" where it almost overshoots
If it were a DJI 550, I'd almost think it was perfectly tuned.  I'm just not sure I want to watch a few thousand dollars "snap" into position.  I can't tell if I need less stick sensitivity or lower gain values.
2016-7-2
DJI-Jamie
bcdebusk Posted at 2016-7-2 19:38
I'm using an LB2.
It flies fairly smoothly with gains at 90.  But when remove elevator or aileron ...
Based on what is provided, lowering both a tad should help. Lowering the sensitivity would allow for the unit to   cruise in that direction, while the gains would help ensure that the weight of the aircraft does not take precedent when braking.
2016-7-2
fans900ac856
Now that a few months have passed, are there "standard" gains for this setup?
Shouldn't there be hundreds of users with this setup?  I'm not excited about spending a full day placing a few thousand dollars of hardware at risk if someone has already done the homework.
2017-2-10
DJI-Jamie
fans900ac856 Posted at 2017-2-10 19:26
In the Gains section, you should see a drop down menu that will generate gain settings based on the size of the aircraft. Have you given that a try?
2017-2-10
fans900ac856
DJI-Jamie Posted at 2017-2-10 22:38
I'll check later today.  This vehicle was assembled back when the A3 was still getting major software updates and I didn't remember any drop-downs like that.
2017-2-11
DJI-Jamie
fans900ac856 Posted at 2017-2-11 04:38
Please keep me posted. They should definitely be there if you're using the latest Assistant 2 software.
2017-2-13
fans900ac856
DJI-Jamie Posted at 2017-2-13 11:57
I updated everything and found the settings.  It's set to the 800<vehicle<1200 range.  I'll see how it flies in a day or so
2017-2-15
DJI-Jamie
fans900ac856 Posted at 2017-2-15 05:38
Good to hear you found it, let me know how it goes when you can.
2017-2-15
fans5e3110ba
Colombia
Hola tengo A3 montado en un frame de 1300mm, configurado en un Octa X8, motores de 135KV, ESC de 95A, helices de 28x9.2,, bateria de LIPO 8S (33V), he ajustado las ganancias por default proporcionada por  la dji assistant, la respuesta en vuelo fue satisfactoria, he volado bien, los motores y las respuestas en Basic y Actitude full muy bien. El equipo tiene una capacidad para volar 32 Kg de Takeoff Weight, sin embargo al mantener esas ganancias no responde correctamente. teniendo en cuenta que el vuelo es en BOGOTA COLOMBIA altura 2600mts sobre el nivel del mar.
Subi las ganancias a 170% y la respuesta fue mejorando. ¿hasta que porcentaje puedo llegar de tal manera que el equipo sea aun controlable?
2017-3-19
DJI-Jamie
fans5e3110ba Posted at 2017-3-19 16:14
In what way do they not respond? Is the aircraft really slow to respond or does it seem to shake a lot? Do you happen to have any video?
2017-3-22
edwoodza
Flight distance : 379177 ft
South Africa
fans900ac856
any update on how it went?
and what settings used?
Pure default 800-1.2m? or did you change them?
what propulsion system bandwidth you set.
2017-3-31
dani2013
Flight distance : 536017 ft
Armenia
Anybody can advice A3 gains for 29-30" props   with LB2   ?
Thx
2017-4-4
DJI-Jamie
dani2013 Posted at 2017-4-4 11:08
Thx
What's the overall size of the craft? If you have the latest Assistant 2 software, you can choose a set of starter gains settings based on your aircraft size.
2017-4-5
VRT_Colombia
Colombia
DJI-Jamie Posted at 2017-3-22 12:56
The response from the plane was slow. When he increased power he went sideways trying to reverse, he got up 30 cms from the ground. The test was at an altitude of 2,600 meters above sea level.
Now I just got LB2, and I have other doubts 1. Are the gains configured from DJI Assistant 2, or from DJI GO App?
2. Do the values ​​behave the same from DJI Assistant 2 and DJI GO App?
2017-4-21
VRT_Colombia
Colombia
Les comento que hice pruebas con LB2 y la verdad, estoy feliz, el equipo se comporta mejor con los componentes dji, el vuelo estuvo fiel con 15Kg de carga.
2017-5-4
dani2013
Armenia
DJI-Jamie Posted at 2017-4-5 06:11
Hi Jamie
it is Gryphon dynamics frame X8 but just using 4 motors
total take off weight around 8-9kg
prop size 29-30"
power 12S
any advises for stable fly gains ?
Thanks
2017-5-27
Inconceivable 7
Pakistan
Hi
Were you able to tune the 29 inch prop frame. I am too usinv same propulsion system.
2017-6-2
dani2013
Armenia
i have select 800>Frame<1200  config on A3's assistant , and default config it could fly not bad
Just the latest firmware of A3 has some problem , got error messages, tilt angle gravity .... .  ,  should downgrade firmware again
2017-7-13
DroneMapperGuy
Flight distance : 4226 ft
I have the S900 with E1200 Pro arms and the A3 Pro, large 26K battery and mid weight gimbal and camera. Any suggestions or links to factory settings?
Thank you all.
2017-7-13
fans33258313
Iran
Hi
i have problem to setup A3 gain setting my X6 isnt stable and moving
i need help to set gain setting
i have tarot t810 frame 15" propller my motors are U5,
and weight of my drone is 7.5 kg
now my setting is
basic gain:
roll:110
pitch: 110
yaw: 120
trothle:120
p.bandwich : 95
advance altitude: 70
thanks
2017-10-14
rcdevil
bcdebusk Posted at 2016-6-25 14:25
Do you know how i can modifiy the gain values on the A3 Pro with a knob on my lightbridge 2?
I have installed the M600 Pro extension panel on my lightbridge 2 remote controller.
2018-9-5
ZamCxPro
Malaysia
fans33258313 Posted at 2017-10-14 11:07
Hi
Hi ,My experience about this i think p.bandwich : 95 is too high  40-60 should be
2019-1-30
